Front axle swap/rebuild
Haven't been on the forum for a while because I have been in college and not driving my truck much. However i had it out this weekend and this happened....
Luckily i was right in front of the house and no harm to me was done. Im thanking the man above because I was headed to my girlfriends place to watch the Super Bowl which included 20 miles of highway driving. The drivers side u joint had apparently come apart and the sharp turn walked the axle up on top of each other and separated the ball joints.
Now that I have my shorts cleaned out I have decided that I am going to swap in an entire new axle. I wanted to go the D60 route but I think I am just going to swap in another 44. I want to effectively rebuild it before I put it in. new joints, new seals, ETC... I am going to try to document the process as much as I can (WITH PICTURES) but I just wanted to get some input from you guys. At this point in time the truck isn't a DD and won't be until the summer months come around. So far I've got in my shopping cart at rock auto the following... New coils, new shocks, new sway bar links, new u joints for the axle shafts, new axle seals, new ball joints, and a new track bar bushing. Am i leaving anything out? I plan to reuse the hubs off my old one because they are less than a year old...
The one under it has a host of problems, first off the shafts are broken, but the spring perches are also fairly rusty with big flakes coming off. The CAD housing is really messed up ( was in it trying to see why 4wd wouldnt engage and sheared one of the housing bolts off. Tried easyout but had to drill and retap and broke the tap off in the hole). Now its rigged up with three bolts and alot of permatex. And finally the carrier has a couple of chipped teeth on the ring gear.
ive also got a line on an axle for $80
Thats what i was thinking. I think i am going to do tie rod ends also. I didnt want to do those but its most certaily going to need an alignment once its done.
You guys should know that I had that truck back on all fours in 10 min to get if off the road, i grabbed a lug wrench and a jack from the house and i just set the steering knuckle back under the ruined ball joints and was able to back it back in the driveway and back into the garage. Luckily i didnt hold up too many people, i was blocking the ENTIRE road.
Need help on a decision. My shopping cart is approaching 1k for all new parts over on Rockauto. My dilemma is this, I want to order new coil springs for the front but they are going to run about 120, but i also wanted to install a posi lock cable locker. Which would you guys recommend? Cant afford both at this time. Going tomorrow to pull an axle, im not going to put the order in until Ive got the new one in hand...
Also, does anyone know the part numbers for all the moog stuff? such as ball joints, ETC?
im ordering new tie rod ends and I'm not convinced Rockauto is giving me the correct right inner and left outer rod ends. Those would be the two little stubby ones; are they the same on the 2WD and 4WD trucks?
