how much boost can a stock 04 5.7 hemi take
I was thinking of putting a single small turbo on the truck something like 5lb its my daily drive don't wont nothing crazy hp plus its all stock beside headers and dual exhaust cant find anybody put a good tune to up the hp buddy mine can get turbo for a good price which it can be adjusted all the way to 10lb.maybe in the furture when I win the lottery ill build the motor to hold all 10lb, but i know I want a mild cam in it so whats a good cam for these trucks
*EDIT* N/M -- The Googles show that these things are about $5,500 +/- for the 5.7L.
thanks for the reply's my buddy can get the turbo way cheaper then then $5k next question is whats a good mild cam for these engine just enough to make it chop mine has a clicking sound, sounds like rocker arm not getting enough oil or it loose that's the reason for the cam while its apart put a good cam in.
yes i did an still using the v6 tranny which is 45rfe soon I'll be changing that to a 545rfe and fuel cell also the og 02 v6 one. it came out of 04 slt so now my base model truck is a slt it has everything electric and also have that thing in the headliner with the compass and the mpg and all.an I don't know if im the only one whos done this motor swap I've seen pic of a few people put no video of them running.
you could have a wiring issue sound like o2 sensor is shorting and making the truck run rich which will cause the misfire or it could be the cam and crank sensor
