Notices
Feeler-- Stainless Steel Brakes Rear Disc Brake Conversion 94 -01 Ram
Old 03-01-2009, 08:52 PM
KiwiRT96's Avatar
KiwiRT96
KiwiRT96 is offline
Default Feeler-- Stainless Steel Brakes Rear Disc Brake Conversion 94 -01 Ram
Hey Guys I just want to see if there is any interest I have the Stainless Steel Brakes Rear Disc Brake Conversion Kit & Front Brake Upgrade for the 94-01 Ram with Rear Wheel Drum Brakes. It is Currently Installed on my 96 Ram. Use Wise I bet there is less then 20 Miles on them , Not Even Broken in Yet. My Truck was Trailored to Shows and this Kit was installed less then 2 Months before it was put into Storage in 2003 and Not Driven Since. The Rear Calipers are Bare Cast Iron as well as the Front ... and I would Powder Coat them to What Ever color you would like them in. I would also Give a Core Credit for your Front Calipers in Return
Rear Brake Conversion Kit
Poduct Part Number A158
Product Features
Rear drum to disc brake conversion kit. Includes single-piston cast iron caliper with built-in parking brake.
All hardware included.
Caliper includes built-in parking brake.
Rotors available with optional Turbo slotting and Xtra Life plating.
Caliper Specs
Name Number of Pistons 1 Piston Size 45mm Constructed From Cast Iron Standard Finish Optional Finishes Powder Coated
Rotor Specs
Diameter 11.25 Thickness 1.000" Venting Uni-directional (straight vane) Standard Finish Standard Optional Finish Slotted and Plated Bolt Pattern 5 x 5.5"
Important Information
Minimum wheel size: 15
Front Wheel Brake Upgrade
Part # 158-2
Product Features
Disc to disc upgrade to larger than stock single-piston cast iron calipers. Bolts to stock spindles.
Includes Turbo slotted rotors with Xtra Life plating.
Vehicle Applications
1994-1999 Dodge Ram 1500 (2WD)
Caliper Specs
Name Number of Pistons 1 Piston Size 80mm Constructed From Cast Iron Standard Finish Optional Finishes
Rotor Specs
Diameter 11.61 Thickness 1.272" Venting Uni-directional (straight vane) Standard Finish Slotted and Plated Optional Finish Drilled Bolt Pattern 5 x 5.5"
Minimum wheel size: 16
Dont Forget to Check out my other parts for sale !!
here is the Thread Links
https://dodgeforum.com/forum/parts-s...age-heavy.html
https://dodgeforum.com/forum/parts-s...um-engine.html
Let Me Know if you are interested !!!
Old 03-02-2009, 01:40 AM
xskylinedx's Avatar
xskylinedx
xskylinedx is offline
how much for the rear conversion?
Old 03-02-2009, 03:04 AM
CAPTJOE's Avatar
CAPTJOE
CAPTJOE is offline
Default 1997 4x4 extended cab 1500
Hi Does this only fit 2 wheel drive??
Old 03-02-2009, 08:30 AM
KiwiRT96's Avatar
KiwiRT96
KiwiRT96 is offline
Yes the kit will fit a 4wd on on the 2g Ram (94-01). The Kit sells for $995 New and I would let i go for $450 plus shipping ... my guess for shipping would be about $35 approx
Old 03-02-2009, 11:49 AM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Dam if I had not just got wheels and tires.
Old 03-13-2009, 05:10 PM
bonestreetkrew's Avatar
bonestreetkrew
bonestreetkrew is offline
do you still have the conversion kit
Old 03-13-2009, 09:21 PM
KiwiRT96's Avatar
KiwiRT96
KiwiRT96 is offline
Yep i Sure do !
Old 04-28-2009, 08:13 PM
gumby's Avatar
gumby
gumby is offline
If this kit is still available, please e-mail me! I am very interested!
Old 08-31-2009, 10:51 PM
shawnsack's Avatar
shawnsack
shawnsack is offline
im also interested if you still have these
Old 11-04-2009, 04:33 AM
Activate's Avatar
Activate
Activate is offline
Already sold?
Quick Reply: Feeler-- Stainless Steel Brakes Rear Disc Brake Conversion 94 -01 Ram
