1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
tranny not shifting
Old May 4, 2007 | 03:53 PM
ls_monk's Avatar
ls_monk
Default tranny not shifting
So my g/f called me up last night said the rpm where at 6000 and she was only going 75mph. Told her to pull over shut it off then start it back up and drive off. Everything was good then. (rpm where at 2500).
I have searched and found that the relays under the hood could be dirty. I am also planning on doing a tranny flush and filter within the next 2 weeks.
Should there be anything else I should be doing to make sure this doesn't happen again?
thanx
Old May 4, 2007 | 03:58 PM
Kalevra's Avatar
Kalevra
Default RE: tranny not shifting
Try checking the tranny fluid... low level of tranny fluid could cause it to not shift/ slip (my friend's honda accord has this problem)
Old May 4, 2007 | 11:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
Yes it could. How low was it? and did it set a ck engine lite code?
Old May 4, 2007 | 11:44 PM
Kalevra's Avatar
Kalevra
It was pretty low... but too much fluid can do the same... and no, it didnt set off a check engine code at all. it's odd. but check the fluid ASAP
Old May 4, 2007 | 11:47 PM
Kalevra's Avatar
Kalevra
by the way. Check the fluid, then the sensors if that isnt it then you have a mechanical problem on your hands and be prepared to put out A LOT for repairs
Old May 5, 2007 | 03:12 AM
sprman9's Avatar
sprman9
may sound really stupid... but was she in overdrive?? cause when i get upto gear real fast my car doesnt shift after about 85ish... and sometimes have to let off the gas for it to shift... idk, just an idea
Old May 5, 2007 | 03:47 AM
master tech
In most cases the 40/41TE transmission will set codes if there is problem inside the trans, Loss of prime or pressure circuit codes. If you have no codes then your chances are good, But without a DRB scan tool it would hard to tell. If you can get your hands on DRB, I would ck the CVI's and perform a clutch test.
Old May 7, 2007 | 03:17 AM
ls_monk's Avatar
ls_monk
wll thanks guy she said it wasn't in overdrive. But I will be checking fluids and relay first thing tomorrow morning.
Old May 7, 2007 | 08:41 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Lol, that can do it, lol. She may have accidentally hit the button. I find that it's very easy to hit it and not know right away that it's off, especially if the O/D light on the dash isn't working. Get that light working if it's not to keep this from happening again
