1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
speaker set up q's
Old May 12, 2007 | 01:09 AM
  #21
bad venge's Avatar
bad venge
Section Moderator
Default RE: speaker set up q's
speaker levels are normally ok...
Old May 12, 2007 | 01:12 AM
  #22
jusplayn85's Avatar
jusplayn85
I have a set of Alpine type-x 6 1/2 components. They sound awesome...The alpine adapter plates require a little bit of trimming and it bolts right in. Not too bad at all.
Old May 13, 2007 | 04:27 AM
  #23
ls_monk's Avatar
ls_monk
Well the install went smooth.Door speakers are LOUD as heck. (still need to be tuned with the rest of the system)
Everything works great except the subs they play great at low volume but as soon as it starts bumping it cuts out for a bit. I replaced the amp wht another. Still continues to cut out. So I am left with the headunit? or subs? The subs are 10" SVC JBL I have 2. If its the subs why would both cut out if it was the subs?
As for the headunit I tried swithing from the Non-Fading preouts to the Rear Preouts and it still continues. I tried running the subs (as trial) off a Kicker kx350.4 bridged to the ONE amp. I also tried running it off a Pioneer GM-7100m amp no difference.
I was thinking if it as the wire size then it would blow the fuse under the hood, right.
The headunit has 4.5 preouts and is a kenwood kdc-x915.
And last but not least they preouts are cheapy one. I have ran these ones before off a Kicker z240@4ohms and never had a problem though.
Old May 13, 2007 | 01:18 PM
  #24
bad venge's Avatar
bad venge
Section Moderator
what impedance are the subs ???
Old May 14, 2007 | 02:00 AM
  #25
ls_monk's Avatar
ls_monk
4 ohms
Old May 14, 2007 | 01:42 PM
  #26
bad venge's Avatar
bad venge
Section Moderator
Siunce you are bridging is the amp 2 ohm stable ????
Old May 14, 2007 | 10:04 PM
  #27
cbccadet2002's Avatar
cbccadet2002
can i run a component system off the factory amp? or is it better to run them off an amplifier? I have a older kenwood 600watt amp that i am running 2 rockfor 10's off of. there are two sets of speakers outputs. should i just use them then?
Old May 15, 2007 | 12:27 AM
  #28
bad venge's Avatar
bad venge
Section Moderator
you can run the components off the factory but DO NOT use the crossover from the components and add a bass blocker to the tweet for safety
Old May 15, 2007 | 01:07 AM
  #29
cbccadet2002
would you suggest this? or just run them off the am i have running my subs? or get a new amp for them all together?
Old May 15, 2007 | 01:19 AM
  #30
bad venge's Avatar
bad venge
Section Moderator
your 600 watts would shred most normal components so that is not an option ...
Using the factory amp is fine ....
Or get a 4X75 and use it to run the components and run the 6X9's from the head unit opwer
