remote entry wiring
RE: remote entry wiring
If you could figure out how to get a decent signal boost (say past 10ft) or maybe make it chirp when lock/unlock that would be beautiful. Although I would bypass the panic system altogether because of the range and because I dont think anyone has ever been saved because of the panic alarm.
Not sure how you'd get a signal boost besides moving the unit from behind the sheet metal; it doesn't even have an antenna.
Yes with the short range of these systems the panic is basically a waste. I couldn't find a "panic" output but when I was messing with the alarm wire, pin 20, my stock alarm went off (I didn't even know it had one, seems the key in the door is the only way to disarm it.)
Maybe I will remove the pin from pin 20 and see if the output changes. I have never understood why people design systems that are hot and given a ground, seems like a lot of wasted power.
I think I have a plan to make the parking lights flash ... on the remote entry harness I'm going to splice into pin 16 (which goes low momentarily when any key on the fob is pressed) and wire it to a relay to trigger the flash of the parking lights (18 Pin Connector at Fuse Panel).
You have been playing with this alot huh? I imagine if you could find some way to keep the panic button from causing a loop you would be set, but thats going to be software controlled. Maybe the wiring to the dome light would work, it turns on once when you unlock and flashes twice when you lock.
RW,
How's the progress going with the mod of the keyless entry system? I was just wondering if you tried anything with the range when you were working with it. If there was any increase when the unit was exposed from behind the panel or not. Would it be possible to move?
