1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Tranny rebuild??
Old Aug 18, 2007 | 09:17 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Tranny rebuild??
Mine was shipped in and back so dunno where they were at ...
Old Aug 19, 2007 | 07:57 AM
Customavenger's Avatar
Customavenger
ORIGINAL: Customavenger
Are making the urathane mounts just as good as buying replacement ones? That almost seems to easy...
Old Aug 19, 2007 | 08:06 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Taking your stock mounts and filling it with urathane won't be as hard as the inserts or urathane replacements, they are are step softer.
I did a spare set of mine and compared to my stock ones....they do not move as freely as stock and the stock ones move just by placing my thumb and finger on either side of the center and moving it around.
The DIY set will not move by doing that. They will move, barely, with a screwdriver slid down the slot and forced to move.
That's my before and after example for you Custom
Old Aug 19, 2007 | 01:44 PM
Customavenger
Thanks silver. One last question for you though. Do you think that filling them myself is worth it for what I need them for or do you think it's worth the money to just go and buy them?? And if you think it's better to buy them do you know where I can buy them because im having a hard time finding anything for my car on the net..
Old Aug 19, 2007 | 01:52 PM
bad venge's Avatar
bad venge
Section Moderator
The link I posted SELLS them filled in Urathane ....
You can melt burn or cut out the stockers and fill them in urathane and they will be stiffer then filling it around the rubber ...
Old Aug 22, 2007 | 02:16 PM
Customavenger
I think im eather blind of im missing somthing because I do not see the place that sells the mounts on that link. I see 3 links one that shows you how to do it myself one that is a diagram and another that gives you install instructions? Sorry but im just not seeing where it says I can buy them?? I have been working 16 hour shifts so I might just be over tired.... Thanks
Old Aug 22, 2007 | 05:29 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.deyemeracing.com/ according to he site they say no longer available .... I'd call and see why not
Old Aug 23, 2007 | 06:01 PM
blackvenge34's Avatar
blackvenge34
wat exactly is a level 10 rebuild and wat about a 6 spd possible?
Old Aug 23, 2007 | 08:17 PM
bad venge's Avatar
bad venge
Section Moderator
If youREAD the post...level 10 is a tranny shop
There is NO 6 speed that will bolt to the motor , so unless you have $8/$10K MINIMUM to spend for custom built bellhousings,adapters and tranny mounts that won't happen...
