1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
3.0 lifters make noise
Old Dec 17, 2007 | 10:56 AM
yanickee's Avatar
yanickee
Default 3.0 lifters make noise
I have a lifter tick, pretty loud when I start my car in the morning. Only happens when it's cold outside, have not noticed it during the summer and nice fall days. Is there anything I can do to get rid of it? It disappears after a minute, but still!
Old Dec 17, 2007 | 11:02 AM
josef15111's Avatar
josef15111
Default RE: 3.0 lifters make noise
what kinda oil you running? was there a lotta miles on your motor when you got it? i have a crapie liffter tick you can hear all the time except when you first start it and when you hit the gas it goes away i use the luccas oil treatment in mine, just trying to make her last till spring lol i heard the marviels mystry oil works good on the ticking i have a bottle gunna try it out in a week or so
Joe
Old Dec 17, 2007 | 12:19 PM
bad venge's Avatar
bad venge
Section Moderator
If you have 40K miles I'd suggest an Oil Flush since you have no idea the oils ect used in it before you swapped ...
http://aseclub.net/forums/How-to-do-...h-t107918.html
Old Dec 17, 2007 | 01:29 PM
yanickee's Avatar
yanickee
I use Mobil full synth, engine has 18K now on it. I know that oil makes difference, just need to shop around and see what works best. Changed oil about 1K ago. Will try different oil and maybe some oil additives to see what happens! And will defenately wait till spring to see what's up inside (cold outside even with 80000 Btu heater, nut risking CO poisoning).
Thanks bad venge
Old Dec 17, 2007 | 11:16 PM
master tech's Avatar
master tech
Site Moderator & Tech
Before your next oil change, put 1 qt of atf in the motor and drive for 2 miles and change the oil and filter. I would 10/30 oil.
Old Dec 19, 2007 | 11:03 AM
yanickee's Avatar
yanickee
Will try ATF trick. Thanks
