1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 avenger 2.5 v-6 will not start
Old Jan 26, 2008 | 01:58 PM
BassMan_T's Avatar
BassMan_T
Default 1997 avenger 2.5 v-6 will not start
Hi, I am new to this site and I have found the Info..on here helpfull..so lets begin.. 97 2.5v-6 avenger..backing out of a parking space and shut off...will turn over just not start..replaced the CPS still nothing..Blink code 12...now what? Thank you Tim
Old Jan 26, 2008 | 02:05 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 1997 avenger 2.5 v-6 will not start
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
Check Battery connections / Informative Code
are you getting the fuel pump to run ???
are you getting spark ???
Old Jan 26, 2008 | 02:09 PM
BassMan_T's Avatar
BassMan_T
Fuel pump is running can here it when you turn the key on..did not check for spark yet...
Old Jan 26, 2008 | 02:16 PM
BassMan_T's Avatar
BassMan_T
the car shut off in shopping plaza center wher there happens to be a advance auto..and a radio shack there soo i am trying to fix it there rather then getting it towed to my shop..are the relays still available at radio shack and do you think that may be the problem.Thanks Tim
Old Jan 26, 2008 | 02:23 PM
bad venge's Avatar
bad venge
Section Moderator
possibly ....A Bosche 30 amp relay works in place of them
Old Jan 26, 2008 | 02:26 PM
BassMan_T's Avatar
BassMan_T
well Thank you for your help..I have to get back down there and see if i can fix it..before dark..I will check this board later ..Thanks again
Old Jan 26, 2008 | 02:46 PM
bad venge's Avatar
bad venge
Section Moderator
No Problem best of luck... You can also swap them and see if the trouble moves .... Swap the fuel pump ,and the ASD and if the pump doesn't run=bad relay
Old Jan 26, 2008 | 04:28 PM
BassMan_T's Avatar
BassMan_T
swap them and bought the last 30 amp five prong relay advanced auto had...tried that and no change..just spins over..i guess my next move is the dist.and cam sensor
Old Jan 26, 2008 | 05:04 PM
bad venge's Avatar
bad venge
Section Moderator
1)check for spark
2)check for voltage at the distributor
Old Jan 27, 2008 | 04:06 PM
BassMan_T's Avatar
BassMan_T
Ok ..Check for spark...notta...how would you check voltage at the dist?.Thanks T
