1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Need Help with Rear Struts ASAP!!!!!
Old Jan 3, 2009 | 11:36 PM
venge96's Avatar
venge96
Exclamation Need Help with Rear Struts ASAP!!!!!
Hey guys,
Haven't posted in a while, anyway, driving down the road today, and I hit a pothole. I couldn't avoid it, and I was doing about 45 m.p.h. Immediately heard somthing rattling in the back left area. I get home and take the seats out of the back and sure enough, the strut is pushing the cap off of itself. So now I need a new strut. I've already taken the entire strut assembly off, but now I need to know how to put a new strut on it. Also, need to know how to compress the spring and all of that junk. Please, detailed insrtuctions would be awesome, and also I have a couple of other questions. Since im replacing one strut, does it mean i have to replace the other one? Next, do I really need to torque everything down to factory specs, or do i just get everything snug? If i do, how do I know what the factory specs are? Thanks for all the help,
Venge96
Old Jan 3, 2009 | 11:56 PM
bgibb68's Avatar
bgibb68
goto autozone and 'borrow' a set of spring compressors....and make sure everything is TIGHT
edit: after you drive around for about a hundred miles or so....get back in there and make sure everything is tight.....good rule of thumb....and then get it aligned
Old Jan 4, 2009 | 09:18 AM
bad venge's Avatar
bad venge
Section Moderator
https://dodgeforum.com/forum/1995-20...ar-shocks.html
I wrote this up the other day ... in your case the top mount may have been damaged ,
The top washer or the bushings may have stripped/been damaged you might get away with just a $35 mount
Old Jan 4, 2009 | 10:09 AM
venge96's Avatar
venge96
Wink
ok, what about having to replace both now that one is bad? Also, do i need to torque evertying down to specs, or just get the bolts snug?
Old Jan 4, 2009 | 10:33 AM
bad venge's Avatar
bad venge
Section Moderator
If the strut is broken , yes replace both ...
Torque specs are there for a reason ...
Buy a $10 torque wrench from harbor freight tools , enough to get the job done ...
Old Jan 4, 2009 | 10:39 AM
venge96's Avatar
venge96
Ok,
Last Question,
What about getting it alligned? Do i even need to if its only the mount thats broke?
Old Jan 4, 2009 | 10:44 AM
bad venge's Avatar
bad venge
Section Moderator
The rear is pretty solid as the way it mounts ... I'd swap and keep an eye on the tires if it starts to wear oddly then get it aligned
Old Jan 4, 2009 | 10:47 AM
venge96's Avatar
venge96
Ok will do thanks for all the help.
Old Jan 4, 2009 | 11:03 AM
bad venge's Avatar
bad venge
Section Moderator
No Problem ... Good luck ...
