fire wall hole
ok then wounld you happen to have any helpful pictures on here this spot is ooo and another thing i have to change my brakes i know how but one of my friends said that i would need a tool to compress the rear plunger on the calaper is this true?and lastly my parking lights in the fron dont come on when i turn the head lights on what could be the problem you have been a big help and i thank you alot this is my first avenger i use to drive a neon but i think i am much happier now
http://img129.imageshack.us/img129/1512/strut4ga.jpg
I can't find a good picture if you lay in the footwell and look up you'll see the triangular area where the clutch cylinder would be mounted drill there
ok thanks alot for the help hey how do i get my motor to look like new it has that faded look and oil stains here and there and on the lights you have inside to light up the floor how many did you use i want to put some in mine but i want to light up the floor in the front and the back did you mount some under the dash and the seat or just the seat thanks alot
Trending Topics
Cleaning the motor if it's really bad start with Gunk Foamy brite engine cleaner degreaser follow instructions , be sure to saran wrap electricals plug wires, cap ect ,Spray and let soak, Scrub the really dirty parts with a brush , hose down ... Also for still dirty areas I've used "Purple Power"
Lights I have a set of Cold Cathodes mounted under both seats one front , one rear,
under the dash I have a Piranha bar mounted under each side :
http://www.oznium.com/
