Tranny problems.....
Ok so I was just driving along and I hear this POP followed by this rubbing sound. Turns out something blew in the tranny and now fluid is leaking from the joint where the engine and tranny meet along with the whole underside of the engine and transmission being soaked with tranny fluid. any ideas what could have happened. the tranny didnt drop out of gear or anything else till I stopped the car. Then it was in limp the way home.....think that is because the fluid was leaking out....and then while getting it on the curb the car dropped out of drive.....i think at this point it had no more fluid. I am waiting for the rest of the fluid to stop falling before I take the pan off and see if the filter was bad and could have contributed to a blow in the transmission or if it is just the pan gasket.
Help is greatly appreciated.....
Please help me BadVenge......
Trending Topics
well mines a I4 but anyway I crawled under her and I think I have found the problem but I need to know if my thinking is correct. If the transmission only gives higher pressure whenever it is in a gear then I think I have found the problem. There is a patch on one of the trans cooler lines and I was drying it off and I felt it move. I tried to move it and it moves reallly easily back and forth so I think that it may be the culperate. The line of fluid vapor on the bottom of the car back to the cat is also a perfect straight line behind it. The patch also looks like it was wider on one side then the other and the wider side is on the side where the line is. Also there seems to be a trail on the skidplate under the oil pan back to the cat and if you count how fast I was traveling in town then it looks like the wind would push it back just enough to be the culperate. Any ideas???
