1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help with 98 Avenger
Old May 27, 2009 | 09:16 AM
nightrider340's Avatar
nightrider340
Default Help with 98 Avenger
OK... here is my problem... a couple days ago it started to idle rough... ran fine though... today the service engine soon light flashed on and off... turned the car off... went and got a hair cut... started the car and it would die unless I keep my foot on the gas... but the service engine soon light was not on... got home took my foot off the gas and it stayed running... but idle a little rough... any help would be appreciated... thanks Rick
Also, if the light isn't on... will it store the codes
Old May 27, 2009 | 02:21 PM
nightrider340
OK went Advance but the service engine liht wasn't on... so no codes... figured I'd change the fuel filter... change it... car ran good for a minute... now the service engine light is on steady not just flashing.... is the service engine light the same as check engine light? thanks Rick
Old May 27, 2009 | 02:45 PM
nightrider340
OK assuming this is the EGR valve(yes I am an idiot) which part do I clean and how?
Old May 27, 2009 | 06:48 PM
bad venge's Avatar
bad venge
Section Moderator
First thing FIRST , I'd run some Seafoam thru the intake system ... It could be just dirt in the intake tract
Old May 27, 2009 | 09:34 PM
nightrider340
OK thanks Venge... now me being a car idiot... how do I do that???
Old May 28, 2009 | 10:33 AM
nightrider340
OK figured it out.... but now it idles a little smoother(still rough) and stalls when coming to stops... guess I'll give it a day or two... I took the cables off the battery and it reset the light.... hopefully it won't come back on and everything works out...
Old May 28, 2009 | 02:56 PM
JLA74's Avatar
JLA74
If the check engine light comes on but then goes off, it should still have a code in the memory. This should at least lead you in the direction if it is fuel or electrical.
Old May 28, 2009 | 05:09 PM
nightrider340
Thats what I was thinking... but it didn't... well some good news... the light started flashing again... hopefully come on steady again then hopefully it will spit out a code... maybe I should run some more Sea Foam thru the intake??? but that will have to wait until tomorrow... have to work tonight
Old May 28, 2009 | 06:08 PM
Darkavenger's Avatar
Darkavenger
If the check engine Light is flashing it is probably a misfire. you should check your spark plugs / Wires / Distributor.
Old May 28, 2009 | 06:23 PM
nightrider340
OK thanks... now I haven't been able to find out anywhere... but is the service engine soon light the same as the check engine light on these... cause I haven't seen a check engine light... thanks
