1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Tranny Issues?!?!
Old Jul 7, 2009 | 06:27 AM
pwilks24's Avatar
pwilks24
Ok will do. Would it be a good idea to flush it and then replace it with the atf+4? And master tech exactly what codes would I be looking for and what are the good codes and bad ones? Where can I go to get the tcm checked out? And what is the difference of using the overdrive?
Old Jul 7, 2009 | 10:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
The only good code is battery disconnect. Any others are not good. Once you have pulled the codes out of the tcm, send a pm to me or bad venge. Or you can post it too. Overdrive is for fuel mileage.
Old Jul 8, 2009 | 12:30 AM
pwilks24's Avatar
pwilks24
Oh ok thanks for that information I greatly appreciate it!. So basically not using the overdrive will help increase on gas mileage?
Old Jul 9, 2009 | 04:07 PM
virginatheavenger's Avatar
virginatheavenger
no no no overdrive gives u better fuel mileage it drops rpms the higher the rpms the more fuel u use but yes ignore your owners manual where it says use dexron 2 it ****s the whole tranny up atf +4 is the best for chrysler tranny's
Old Jul 9, 2009 | 05:30 PM
pwilks24's Avatar
pwilks24
Ok thanks virgina I'm gonna try to flush and refill with the atf+4 and see if it helps hopefully.
Old Jul 12, 2009 | 11:20 PM
virginatheavenger
no problem i would rather see some one save the 1500 for a new tranny to mod their car or spend it on what ever b/c i learned my lesson there
