1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Dodge Avenger 1995!! dervech
Old Aug 10, 2010 | 09:10 AM
dervech's Avatar
dervech
Unhappy Dodge Avenger 1995!! dervech
the transmission did not change when you start the car, but if you turn it off and the turn it on again, the transmission work good, but later the problem came back, no check engine light on, the scanner said that LOW REVERSE SOLENOID falult, what do i have to do it to Fix it
David Reyes - Puerto Rico
Old Aug 10, 2010 | 07:28 PM
bad venge's Avatar
bad venge
Section Moderator
it can be a clogged passage or a bad solenoid
Old Aug 11, 2010 | 01:44 PM
dervech's Avatar
dervech
How many Solenoids have the Avenger?? whats the clogged?? i really dont know what it is? thank you!!!
Dave
Old Aug 11, 2010 | 04:57 PM
bad venge's Avatar
bad venge
Section Moderator
It can be a passage INSIDE the tranny clogged causing low pressure to the solenoid pack Do you have the EXACT code #
Old Aug 11, 2010 | 09:51 PM
PappiDread6's Avatar
PappiDread6
There are alot of passages (vains) inside a transmission to control and direct the about of transmission fluid flow. if there is a restriction to your reverse solenoid then enough pressure will not build up to engage the reverse clutches.
Depending on how many miles on you avenger I would have your transmission flushed. So shops won't touch it if its over 100,000miles and/or if the fluid is serverely burnt.
Old Aug 12, 2010 | 01:56 PM
dervech's Avatar
dervech
No I dont have the specific code, but the scanner said Low-Reverse Fault, Papidread- the car has 110,000 miles, question may I try to change the transmission filter?? or change the solenoid, and which solenoid I have to try first??
thank you Guys!!! I Appreciatte
Old Aug 12, 2010 | 04:51 PM
bad venge's Avatar
bad venge
Section Moderator
A flush and Filter change may help , but can't be sure without the code
Old Aug 12, 2010 | 05:12 PM
dervech's Avatar
dervech
as soon as I have the code number Iwill let you know!!!! thak you my friend!!!
David- Puerto Rico!!!
Old Aug 12, 2010 | 05:15 PM
dervech's Avatar
dervech
If I continuing using the car, the transmission can suffer damages????
Old Aug 12, 2010 | 07:03 PM
sapporo's Avatar
sapporo
sí, puede dañar la transmisión
