1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
1997 avenger sport
Old Sep 10, 2010 | 12:17 AM
mcrae's Avatar
mcrae
Default 1997 avenger sport
hello i am new to the site and dodge avenger's i bought the car from a friend of mine that had it parked was park in January. driving as his everyday driver then parked it because his truck was ready to go on the road then he went out and tryed to started it and had no spark i have done a tune up changed the valve cover gasket and distributor and still no spark any idea what i it could be
Old Sep 10, 2010 | 07:14 PM
bad venge's Avatar
bad venge
Section Moderator
Do you here the fuel pump kick on ?
Old Sep 12, 2010 | 01:06 AM
mcrae's Avatar
mcrae
i pulled the back seat up and i can hear the pump turn on and off
Old Sep 12, 2010 | 08:21 PM
bad venge's Avatar
bad venge
Section Moderator
Check for voltage at the fuel pump does it stay on or toggle on/off with the pump ?
Old Sep 12, 2010 | 08:47 PM
mcrae's Avatar
mcrae
sorry i donrt have a volt meter i do have a test light and i unplugged the pump the light turn in and stayed on for 2-3 second the turned on when i turn the key to start it comes back on then stays on for 2-3 seconds
thanx for help
Old Sep 12, 2010 | 09:21 PM
bad venge's Avatar
bad venge
Section Moderator
need to see if it stays on plugged into the pump, I'm trying to see if it's the fuel pump relay or the ASD relay
Old Sep 12, 2010 | 10:42 PM
mcrae's Avatar
mcrae
with the pump pluged in turn key on light turns on the gose out when pump stops making noise i saw your post on how to test cps and i have 5 on one 14 on the next and the last one has 0 when i put a socket to it the numbers do noting a buddy came over with a multi meter hope that helps
Old Sep 13, 2010 | 04:52 PM
bad venge's Avatar
bad venge
Section Moderator
I'd try the ASD relay
Old Sep 19, 2010 | 08:32 PM
mcrae's Avatar
mcrae
thanx man for the help
