Transmission Issues
Transmission Issues
I have a 95 Dodge Avenger that the transmission went into limp( I believe). It will not shift above 1st gear and if the rpm's get to high it goes into a neutral state, shuting off and restarting car returns it to the limp mode. The input and output speed sensors have been replaced and the relay on the firewall was swapped with another one. The speedometer does not accuratly post speed, sometimes stays at zero and sometimes comes as high as 30 mph. What could be the problem? I don't have a OBD I tool, I counted the flashes of the engine light and there are know codes. Any help at this point would be greatly appreciated.
Who makes a tranny specific code scanner?
My 95 avenger had the obd2 port and the MMC port. I have an adapter cable that connects to the pair into my scanner.
The output speed sensor was brand new and there is no way to adjust the gap on the speed sensor, it is enclosed in plastic and you can not set the depth. If there are tranny codes is there a way to just clear them to see if putting in the sensors fixed the problem? Can you take just the TCM into a Dodge dealer for them to reset it, I live quite a ways from a dealer so it is difficult to get the car there?
Tranny shops have the same quality scanner that does everything besides transmissions that I have. At home, I use reader that does Transmissions, Engines, ABS, Air Bags, Body, Chassis/Suspension, etc. I paid $300 for it on Ebay.
Trending Topics
I have read that the TCM will learn your driving characteristics. do I need to have the TCM reset to factor settings or will getting the codes read and cleared take care of this for me? Also if the TCM needs to be reset to factory settings can any transmission shop do this?
No, when you disconnect the battery, the TCM reverts to factory settings. as you drive, it adaptively learns. the ONLY time you need to have reprogramming done is if you replace the TCM or put on different size tires and want the speedometer to read accurately. A used Snap-on MT2500 scanner (found on ebay for under $500) has the capacity of doing everything you are asking about. Just about every high school with an auto class has one of these scanners. Heck I have 4 of them (OCD thing)
