1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Start problem PLEASE HELP 98 avenger
Old Apr 3, 2012 | 08:45 PM
bad venge's Avatar
bad venge
Section Moderator
CPS is on drivers side of engine near battery tray ...
the paper is a spacer , how did he space it ?
If it was too close it could be hit/damaged too far it won't pick up correctly
Old Apr 4, 2012 | 01:09 AM
dodgeavenger98's Avatar
dodgeavenger98
he said he pushed it all the way down? is that good or bad? if bad how should it be installed
Old Apr 4, 2012 | 09:32 PM
bad venge's Avatar
bad venge
Section Moderator
As mentioned the cardboard IS the spacer you put it in on the sensor tighten it and the spacer will fall out
Old Apr 12, 2012 | 06:12 PM
dodgeavenger98
ok i orderd new spacers and got a new CPS.. put the spacer on tightened it all the way down. and still nothing car cranks but wont start
Old Apr 12, 2012 | 06:13 PM
dodgeavenger98
