1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Start problem PLEASE HELP 98 avenger
Old Apr 1, 2012 | 11:37 PM
dodgeavenger98's Avatar
dodgeavenger98
Question Start problem PLEASE HELP 98 avenger
hi, about a month ago i parked my avenger 98 in my garage backwards to tint the windows. i had the car in power but not tuned on because i was listening to the radio. after i was done. i turned the car on and it started to shake very bad.. like there was a earthquake. when i pressed the gas it would keep going.. but as soon as i let off. the car would start to slowly shut down. this was about a month ago.
- the car has not turned on ever since. i have changed spark plugs, sparkplug wires. distributor, i even have a new oil pump. which i did not put in yet. i also put 98 octain the car car before this problem. but i have used the gas a few times before as well.
- can anyone please help me. i love this car and i want it to run again.. please someone help me.. i am out of luck.
Old Apr 2, 2012 | 05:35 PM
bad venge's Avatar
bad venge
Section Moderator
Have you charged the battery or jumped it ?
Low voltage can cause issues
Old Apr 2, 2012 | 07:56 PM
dodgeavenger98
yes i have. i changed the battery too. even tryed to jump start it. the car will crank. but it will not turn on for some reason. i have no idea why. i have replaced all 6 spark plugs ngk iridium.. and some other stuff i listed above.
my engine is a v6 2.5l auto.
Old Apr 2, 2012 | 08:27 PM
bad venge's Avatar
bad venge
Section Moderator
are you getting spark ?
Old Apr 2, 2012 | 10:48 PM
dodgeavenger98
yes i am getting spark.
Old Apr 3, 2012 | 02:07 AM
dodgeavenger98
but car still just cranks.. like it wants to start but it cant...
Old Apr 3, 2012 | 04:08 PM
bad venge's Avatar
bad venge
Section Moderator
Sounds like the CPS to me
Old Apr 3, 2012 | 04:48 PM
dodgeavenger98
what is a cps and where is that found?
Old Apr 3, 2012 | 04:51 PM
dodgeavenger98
changed that too.. but the car still does not turn on.. now when my brother was installing that. he said the paper or someting was missing..
Old Apr 3, 2012 | 04:54 PM
dodgeavenger98
and can u show me pic to just make sure i got the right one.. eh
