1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Stalling and rpms drop to 0 while driving
Old Oct 6, 2012 | 02:37 AM
jpk123's Avatar
jpk123
Default Stalling and rpms drop to 0 while driving
98 avenger 6 cyl. intermittent stalling attempts while at idle but never fully shuts off and now while driving it randomly loses power and drops rpm's to 0 at speed. runs rough when this happens but any other time it runs like a new car...ideas anyone???
Posted from Dodgeforum.com App for Android
Old Oct 7, 2012 | 12:26 AM
jpk123's Avatar
jpk123
took to Autozone to get check engine light checked and they said it was O2 sensor and crankshaft position sensor....would either of these be causing my problems?
Old Oct 8, 2012 | 12:20 PM
bad venge's Avatar
bad venge
Section Moderator
I doubt the O2 sensor , the Crank sensor causes dying but won't restart usually
It sounds more like you have an idle issue ,
I'd clean the intake and run seafoam thru it first , if she still stumbles remove the EGR tube of the passenger rear and block it off with a metel "gasket" and reinstall if the car runs/idles you have a bad EGR
If she still won't idle remove the Idle Air Control and clean it and reinstall
Still no idle replace the IAC
Old Oct 23, 2012 | 08:17 AM
jpk123's Avatar
jpk123
ended up being the crank sensor. but now 2 days later im getting the multiple cylinder misfire flashing CEL. the car is running strong, no idle issues, no loss of power, any ideas?
Old Nov 1, 2012 | 07:18 PM
RedWraith's Avatar
RedWraith
Default 98 avenger 6 cyl. intermittent stalling attempts while at idle
my 1999 avenger had that problem it was a bad ground on my battery if your throttle cable is heating up its a bad ground for sure. check engine ground too ground battery to car also. strut tower should have a spot.
Old Dec 4, 2012 | 05:12 AM
jpk123's Avatar
jpk123
checked grounds, checked idle probs, ran seafoam thru, ive developed an oil leak out of rear valve cover. im thinking the rear plugs r fawling out
Old Dec 4, 2012 | 06:11 AM
bad venge's Avatar
bad venge
Section Moderator
Have you tried blocking the EGR off ?
Old Mar 6, 2013 | 08:17 PM
kimzilla's Avatar
kimzilla
Default Delete
Delete
