1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
99 avenger no spark issue HELP Please
Old 12-20-2013, 09:08 PM
ars19772010's Avatar
ars19772010
ars19772010 is offline
Default 99 avenger no spark issue HELP Please
First off Merry Christmas Everyone. hello my name is russell. i have a 1999 dodge avenger es 2.5l v6 with no spark issue. ive replaced coil in distributor and tested asd relay output at distributor and yes it is getting power. any help would be greatly appriciated.
Old 12-20-2013, 10:56 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
there is a sensor in the distro that will give a no start , unfortunately I think you need to buy the distro
Old 12-21-2013, 10:19 AM
ars19772010
Is there any tests I can run that will give me a better idea before I go spend 220.00 for a new distributor. Thanks
Old 12-21-2013, 06:57 PM
bad venge's Avatar
bad venge
Section Moderator
I went to the junkyard $35 for a used one , swapped/ran then bought new one keep the used one for troubleshooting
Old 12-23-2013, 11:50 PM
ars19772010
There is another plug on distributor. I believe it's a six way connector. What are these wire for the yellow does not have any power at all is it suppose to .
Old 12-23-2013, 11:52 PM
ars19772010
Says it's a 8 v supply?????
Old 12-24-2013, 06:16 PM
bad venge's Avatar
bad venge
Section Moderator
I'm traveling for the holidays don't have my manual handy , I think it comes off the computer
Old 02-11-2014, 09:11 PM
ars19772010
99 avenger keeps burning up distributors!!! Please HELP! Does anyone know what's causing this? And what's the fix? Replaced 4 distros in two Wks. Starts right back up and runs fine for a few days. And does it agian
Old 02-12-2014, 09:04 AM
bad venge's Avatar
bad venge
Section Moderator
Are you getting remanufactured distro's ? I'd try another company/ brand I've not heard of this before , have you checked that there is no 12 volts feeding with the key off ?
Old 02-13-2014, 09:29 AM
ars19772010
On which wire is dat the black and red on the two prong plug (asd feed)
Quick Reply: 99 avenger no spark issue HELP Please
