1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
97 Avenger excreting white smoke
Old Aug 9, 2014 | 08:06 PM
Rhino42035's Avatar
Rhino42035
Default 97 Avenger excreting white smoke
Alright yet again I come for some advice. It's the ES 2.5 and has white smoke that looks to be coming out of the exhaust manifold, and even the resonator. Need some input on possible causes so I have a better chance of attacking the issue. It's all new to me.
Old Aug 9, 2014 | 09:15 PM
not coming out the tailpipe? Only the manifold and resonator? Are there big holes in the manifold and resonator that are leaking exhaust gasses?
Old Aug 9, 2014 | 09:18 PM
simmonsfr's Avatar
simmonsfr
White smoke is usually coolant in the combustion chamber. Sounds like a head gasket or cracked head.
Old Aug 10, 2014 | 07:21 AM
Rhino42035's Avatar
Rhino42035
No holes that are noticeable. And nothing out of the muffler.
Old Aug 10, 2014 | 09:06 AM
I'm trying to understand how smoke is coming OUT of the exhaust manifold and resonator if there are no holes in them. The only hole in the exhaust system is the hole at the tailpipe for exhaust gasses to exit. While true, white smoke is coolant, it should be coming out of the tailpipe.
Old Aug 10, 2014 | 10:22 PM
simmonsfr's Avatar
simmonsfr
Is there anything at all coming out of the tailpipe? Could it be plugged up?
Old Aug 11, 2014 | 07:47 PM
Rhino42035's Avatar
Rhino42035
That's what I'm not understanding either. I'm guessing the holes might be to small for me to actually see. An the only time anything comes out of the tail pipe is if I mash down on the gas. I think I'm just gonna have to take it into the shop. Which saddens my pockets.
Old Aug 11, 2014 | 07:51 PM
Are you sure something is not dripping onto the exhaust manifold and burning?
Old Aug 12, 2014 | 12:26 PM
smokesxt's Avatar
smokesxt
Are you sure your muffler isn't plugged? This would cause the exhaust to back up and come out any hole it can find. The moisture build up in the exhaust would make it look white.
