SuperAvenger!?
There hasn't been any documented 6G72, twin turbo equiped Avengers, like you would find in a 3000gt VR4 or a Stealth R/T TT. There have been claims of them, but no one could post pics of the motor or any kind of proof. Besides that motor is too tall for our engine bays and the firewall would need to be moved in towards the cabin for it to work. Not that it could be done, but that is a lot of work. The top end of the motor would have to be modified or the hood would have to be moved up with a very long cowl just to fit. A lot of work, but it can be done. No one has been brave enough or has enough money to take on that task though.
Sadly, you can't swap the two motors with the two trannys in the way you're thinking of Pappi. That would make a lot of people happy though, lol.
ORIGINAL: silvercoupe97
I'm not quite sure about having a Super Avenger though DR, lol, thanks though bro!
However, your car is definitely "Super" worthy. To be one of 3 AWD Turbo'd Avengers.....and to be one of what I like to call super sleepers to begin with.....I think its a damn sweet ride.
There is a fourth 4g63 AWD Avenger now. He's got to tune then it'll be up and running the streets. So, in the next month or so, there will be two AWD Avengers rippin' the streets! He's got a body kit and he's bagged too. I think he should strip the air bag suspension because IMO it won't hold up to AWD launches at all, that's a lot of stress on them everytime he takes off hard, plus the fact that they are softer than stock spring.
The other two are still getting there, progress is slow on them for some reason though.
there actually was a twin turbo avenger v6 a while back
he had everything up and runnin except for the rear turbo had a drain issue which is why exile set theirs with a single
too ba dyou dont have a 4 cyl
it it soo much easier to build power
next spring ill post some track times when i finally get mine ready to run down the strip
shes down due to burnin a clutch
ya there was a guy in northern pa alain built the manifolds for the stock 2.5 and it did run till one of the turbos seized due to the oil not drainingif the turbo would have been up 3-4 inches more it would have worked or perhaps a pump system on it
