1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
shifter help
Old Feb 14, 2007 | 11:47 PM
  #21
blackvenge34's Avatar
blackvenge34
Default RE: shifter help
yea its on the last hole but like when i go into first the pivot bracket moves up then it goes into gear then when i go into second the pivot bracket moves back then it shifts into second it seems longer and off i dunno ill look at it again i guess
Old Feb 14, 2007 | 11:53 PM
  #22
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
If you look at the bottom hole, that should have the welded bolt going through it and it should be tight. The bolt above that should be tight too, but that is the only part that should move..the shaft, not the entire bracket. I would definitely check it again to be sure that the bottom nut and washer are tight.
Old Feb 15, 2007 | 12:23 AM
  #23
blackvenge34
so the pivot bracket (purple thing) it doesnt move forward and back?
Old Feb 15, 2007 | 12:31 AM
  #24
silvercoupe97
Uber Moderator
ORIGINAL: blackvenge34
Nope, it should not move at all. Check the welded bolt and make sure that it didn't break free from the weld. The bearing is the only thing that should allow movement of the shifter, that bottom bolt should not allow the purple bracket to move at all. You may need to put a washer on the welded bolt, then the bracket, then another washer, and finally the nut.
The bracket should not move at all.[sm=smiley20.gif]
Old Feb 15, 2007 | 10:10 PM
  #25
blackvenge34
ah ha i think i figured it..at the endof the stock bolt for the shifter its round and not allowing the purple peice to go all the way to the end causing it to move forward so i need to grind it down like a millimeter or so then it should fit all the way across so hopefully thats the end of my problem all this for a shirt shifter lol
Old Feb 15, 2007 | 10:32 PM
  #26
silvercoupe97
Uber Moderator
I think I know what you're saying. Sounds like what you're telling me is that the bracket wasn't sitting on the ledge like these two are.
This is the one I just installed in my buddy's car. Notice the little gap between the bracket and the ledge? It doesn't matter if it's there or not. That thing is tight and it may move, if he shifts it hard, but I put enough loctite on the bolts so that it shouldn't come loose in the near year or so (if left alone). This one was set on 50% shorter throw.
[IMG]local://upfiles/17025/12A9E96C860548C3AAE3A26C190F15C8.jpg[/IMG]
This one is mine...ignore the mess. See how the bracket sits on the ledge? Also, if you can see, I've got my linkage in the 35% shorter throw and not on the very bottom hole.
[IMG]local://upfiles/17025/23987AC965A042CBAB28D4EB3DF26A43.jpg[/IMG]
Old Feb 16, 2007 | 12:52 AM
  #27
blackvenge34
yup thats what i figured this morning but the welded bolt sticks up a millimeter or so so i have to trim it a little so it will slide over the edge thanx for the pix tho
Old Feb 16, 2007 | 02:18 AM
  #28
silvercoupe97
Uber Moderator
I would try every option, like a rubber mallet before you start trimming anything. You never know what that might do if you have to buy another shifter.
