1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Air Filter + check engine light
Old Mar 28, 2007 | 05:35 AM
Pisces's Avatar
Pisces
Default Air Filter + check engine light
Hi,
I own a 1996 Avenger, and last week i decided to puton a ConeAir Filter to replace the stock one.
It works fine and it give mea little morepower.
After a full day testing it, i've decided to show it to one of my friend.
So, I was park in a parking lot sitting in my car. I decided to start the engine andgive it some throttle justto let hear the sound of my filter to my friend. I took me about 5 sec. and then the check engine light up.
Iwould like to know what could be the cause of that.(CHECK ENGINE LIGHT)
His there any sensor or what ?
Now i put the stock filter back on and unplug the battery about 10 min to reset the computer.
No more check engine light.
Please help me !
I would like to put ona cold air intake, but i don't want to break anyting and even have a check engine light always on.
N.B: I just want to let you know, that i'm From Quebec, i not a perfect bilingual, so excuse me if the question are not very clear. I try to do my best to be understand. Thanks !
Old Mar 28, 2007 | 06:28 PM
blackvenge34's Avatar
blackvenge34
Default RE: Air Filter + check engine light
id say put the cone back on see if the light comes on then do the key test see what code comes up then tell us what number pops up and most likely silver can tell u what code it is
Old Mar 28, 2007 | 07:08 PM
Pisces's Avatar
Pisces
Thank you!
I'll try it soon!
Old Mar 29, 2007 | 02:28 AM
PappiDread6's Avatar
PappiDread6
ORIGINAL: blackvenge34
Also if ur n a rush you can just Click on the top left that says "Dodge Recalls & TSB's" I think in there they have a section where it list ALL the codes for our cars. If its not there its one page back where your at the Dodge Forum Home page under what listing I don't know.
Old Mar 29, 2007 | 02:32 AM
PappiDread6
https://dodgeforum.com/m_126008/tm.htm Either this is it or its in our sticky at the top of the post. I know I say it in here![:@]
Old Mar 29, 2007 | 11:22 AM
Pisces's Avatar
Pisces
Thanks To You PappiDread6& blackvenge34
I Just Put The Cone Back ON Yesterday and No Check Engine Light Till Now.
Just Gotta Wait To See If The Ligth Goes On Again.
Thanks Again !
Guylain
Old Mar 29, 2007 | 09:59 PM
blackvenge34
ok kool welcome
Old Mar 29, 2007 | 10:14 PM
blackvenge34
question tho the number the check engine flashes is diff then the codes listed how do we know i think i got a number 12 but how does that corespond to the code givin. i think but not sure to hold this against me but i think i got 12 or sumthin like that and it was code 301 i think st alon thoes line if u get what i mean
Old Apr 2, 2007 | 02:21 AM
Pisces's Avatar
Pisces
Ok
I Got a Check Engine Light again. I do the key dance but i dont know what code it is.
Pis for pause.
So the check engine light blinklike that.
1p2p2p1p5p5p1.
Help me understand please
Old Apr 2, 2007 | 03:08 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
You have a 12, 21, and 55. I'm not sure where the extra "1" came from, unless you got a 51, which states a lean condition in one or both banks (front/rear o2 sensor). I don't know if you have a V6 or I4, not that it matters a whole lot, but 51 for an I4 just means lean and 51 for a V6 is what I stated above.
12 = just means that power was removed within the last 50 times you started the car - normal since you removed the battery to reset the light.
21 = means that there's something wrong with one of the o2 sensors or it's readings (again, it's motor defined)
51 = means a lean condition in one or both banks (front/rear o2 sensor), if you have an I4, it just states a lean condition (because they only have one bank) - makes sense since the RAM sucks in more air, it's just hot air.
55 = means end of trouble codes
A "P" code will narrow it down and you can get those codes from Autozone and they check them for free. This also happened to me when I installed a short RAM. In the end, the RAM injested hotter than "normal" air. With the stock box, air that is injested is ambient (that's the whole theory with the box) but the RAM injests engine bay air which gets even hotter when it's been driven for awhile.
If you could, do the key dance again or get the codes read and repost.
**ok, well, I'm not sure why that just got the strike outs, but that's not me. So, try to read "between the lines", lol.**
***ok, well, now they're gone....I'm must be getting old, lol***
