'91 standard trans stick won't stay in reverse
Old Jun 5, 2019 | 11:35 PM
KevinSandidge's Avatar
KevinSandidge
Default '91 standard trans stick won't stay in reverse
Hoping for a cheap and simple solution over here. When i put my truck in reverse, the shifter won't stay put. I have to hold pressure on the stick to make it stay in gear while backing up. What's happening? Linkage issue? Thanks!
Old Jun 6, 2019 | 07:32 AM
What engine/trans?
Could just be some worn bushings inside the trans, that don't allow the gears to full engage.
Old Jun 6, 2019 | 08:07 AM
KevinSandidge
I have the 3.9 la motor; dont know what to call the standard 5 spd transmission. tragic that those bushings you referred are located on the inside; that would be a beefy repair bill.
Old Jun 6, 2019 | 01:57 PM
Where is your shift linkage? Does the lever go directly into the trans, or are there linkages on the side of the trans?
Old Jun 6, 2019 | 05:20 PM
KevinSandidge
I'll have to wait and run that by my mech buddy next time he comes over. I can work with it for now. Thanks buddy
Old Jun 7, 2019 | 03:50 PM
93 ragtop's Avatar
93 ragtop
They are inside. All internal.
Old Jul 8, 2019 | 10:56 AM
KevinSandidge
Do i have the "AX15" transmission in my 91 3.9 2wd? Would it help anything to replace the gear oil in there? Thanks
Old Jul 8, 2019 | 12:49 PM
00t444e's Avatar
00t444e
My 98 has the AX15 and I know Chrysler started using the AX15 In jeeps in the late 80s so yours is probably an AX15, there is no shift linkage, it is a top load transmission.
Old Jul 8, 2019 | 12:51 PM
KevinSandidge
Thanks; i may want to shop for another one at some point.
