Code not found in FSM
Old Sep 14, 2021 | 01:13 PM
Mr.E.Mann's Avatar
Mr.E.Mann
Default Code not found in FSM
1991 5.2 RWD. I have a code popping up as 12. But my FSM doesn’t list a 12 in it that I’ve seen. Anybody have any ideas?
I did switch to LED on the exterior lights and did not add any resistors and have an idea this may play a part in it.
The other code it’s showing is temp sending unit excessive,(can’t remember the code number off the top of my head). I do have it heating up and some days it almost goes to the overheat mark on the gauge. It sat for a couple years and on my first drive after doing the water pump it did overheat, but that was over a month ago and I believe close to 100 starts since then.
Thanks in advance for any and all ideas!
I just got back and checked the OBD & it’s codes are as I said before 12 and the other code is 22.
22 says coolant temp sensor input below minimum acceptable voltage or above maximum acceptable voltage.
Old Sep 14, 2021 | 09:39 PM
RalphP's Avatar
RalphP
12 is "Battery has been disconnected in the last 50 run cycles" (which isn't a start and turn it off, BTW, but a drive cycle of some sort - haven't found out what Chrysler wants for that.)
Perfectly normal if you've had the battery out.
Not so normal if it's been rocking right alone and all of a sudden kicks it.
(It's actually, to quote from my 1988 book, "Direct battery input to PCM was disconnected within the last 50 key-on cycles. " )
22 means the coolant temp sensor is either way low, or way high. And they're talking about the two-wire ECT, not the one wire gauge sending unit.
I'd also check the wiring; my 1988's wiring insulation was shot for that run due to age, so I had to buy a pigtail and splice it partway up into the harness down the passenger side intake.
BTW - Save Dakota Trouble Codes (dakota-truck.net) in your shortcuts or favorites.
RwP
Old Sep 15, 2021 | 03:29 PM
Mr.E.Mann's Avatar
Mr.E.Mann
Once again, Thank You Ralph.
That explains most of it for me.
a couple of years ago I had parked the truck in our apartment complex and was doing a little work on it when I had extra time and didn’t want to drive it with expired tags. Some punks stole it and took the
stereo and battery then left it in another complex less than 6 blocks away, it was found about 4 days later while I was out of town. I know they were young punks because I had not cleaned out the IAC& had it disconnected and would have to power brake it to keep it running while at lights and such. There is a joke about car anti theft devices for the younger generations, the third petal. After that I took the battery out while I amassed the suspension parts. Once I did my suspension rebuild and brought it back home I was unhooking the battery nightly to keep it safe.
We moved out of that ghetto complex a couple of weeks ago, finally!!!!
Old Sep 16, 2021 | 09:43 AM
ol' grouch's Avatar
ol' grouch
You should have had code 55 too. That means end of test cycle.
Old Sep 17, 2021 | 02:15 AM
Mr.E.Mann's Avatar
Mr.E.Mann
It did but it does give that in the FSM
Old Sep 24, 2021 | 11:31 AM
bronze's Avatar
bronze
Doesn't all code reading sequences start with 12?
Old Sep 24, 2021 | 02:18 PM
RalphP's Avatar
RalphP
Actually, no.
Currently my truck will toss a 15, VSS voltage too high or too low, and a 55. But no 12.
RwP
Old Sep 24, 2021 | 02:52 PM
bronze's Avatar
bronze
Originally Posted by RalphP
Actually, no.
RwP
Hmmm, mine always starts with a 12. Always has. I always ignored it and went to any codes that flashed before the 55. I think the 12 is a common snafu with those OBD1 readers. Lots of people get that 12 code first.
Old Sep 24, 2021 | 03:48 PM
RalphP's Avatar
RalphP
If the battery voltage drops enough, it'll trigger it.
It's not SUPPOSED to be the "always starts with" code, though.
RwP
Old Sep 24, 2021 | 04:12 PM
12 just means the battery has been disconnected in the last X (50, I think...) key cycles. So yeah, if you disconnect the battery to reset codes, it takes a while for that one to clear. It won't turn on the check engine lite though.
