93 Dakota
Old Dec 9, 2024 | 05:13 PM
Trev Simpkins's Avatar
Trev Simpkins
Default 93 Dakota
Hi all, Im looking at buying a 93 Dakota sport with a 3.9 Magnum, Im just a bit confused as it has a Carb fitted! Is this ok or should I be concerned its had an older motor fitted? Thanks.
Old Dec 9, 2024 | 07:56 PM
How many bolts in the valve covers? Should be 10 if it's really a magnum. Factory, that should have been MPFI.....
Old Dec 10, 2024 | 11:19 AM
Trev Simpkins
Thanks Hey you, I wont get to see it until Friday! Ive been told it had a rebuild before the current owner bought it and he sent me the chassis number which confirms it should be MPFI, he said its always had a carb on it! Where would I find the engine number? Thanks Trev.
Old Dec 10, 2024 | 11:42 PM
Btyansmith897's Avatar
Btyansmith897
Are you sure you aren't looking at the throttle body on top of the motor? I thought mine had a carb when I took off the air cleaner the first time. It has Holly stamped on it and at a glance looks like a 2 barrel carb. Then I saw the fuel fail and injectors and it all made sense , lol.
Old Dec 11, 2024 | 09:41 AM
There's a valid point. However, MPFI came about in 92, when Dodge went from the LA series engines, to the magnums.
Old Dec 11, 2024 | 10:29 AM
Trev Simpkins
Thank you both, I think that could be the reason I thought it had a carb on it, Im used to seeing the throttle body sideways on and not horizontal! You learn something every day, best regards Trev.
Old Dec 11, 2024 | 10:56 AM
ol' grouch's Avatar
ol' grouch
I bought a '93 new back in 1993. It had the throttle body that looked like a carburetor. My truck had the 3.9, but that's just a cut down version of the 318.
Old Dec 11, 2024 | 12:35 PM
tndakman's Avatar
tndakman
Yep, my '92 5.2 had MPFI as that was the first year for the Dakota w/a magnum. Throttle body FOR AIR ONLY was a Holley , & I'm quite sure a lot of discussions were started over FI vs carb.
