Loose Timing Chain?
Old May 22, 2007 | 02:33 AM
justindubois's Avatar
justindubois
Default Loose Timing Chain?
On sudden throttle input, or above 2000rpm, my 89 V6 Dakota has a rattling noise coming from the engine. The Belts and Fan do not appear to be rubbing anything, so I'm wondering if this is what a loose timing chain sounds like?
The engine has 244,000 mi on it, and the chain has never been replaced.
Suggestions?
How hard is it to replace a timing chain/gear set?
Justin
Old May 22, 2007 | 10:28 AM
BAnders's Avatar
BAnders
Default RE: Loose Timing Chain?
check your idler and tensioner pullys too, im not sure about the timing chain, maybe someone else has more on that
Old May 23, 2007 | 03:02 AM
master tech's Avatar
master tech
Site Moderator & Tech
There is an updated timing chain kit, because the chain does rattle. If would like the kit number PM me or post it. Leonard
Old May 25, 2007 | 02:56 PM
justindubois
Yes! I could use the part number.
Old Jun 2, 2007 | 10:48 PM
justindubois
Now that I have fixed my chewed vac lines, my truck runs worse. When I lightly press the throttle, it hessitates. Sudden throttle input revs ok. I got this wierd tail wagging the dog idle issue after a throttle input, and eventually it settles down. I'm thinking again, this points to a loose timing chain.
Old Jun 3, 2007 | 03:42 AM
master tech
Here is some pert numbers, which is all mopar numbers.
83507095 Chain and sprocket package
53021057 Chain gasket cover
02129013 Water pump gasket 1990-1991
04483757 Water pump gasket 1992-1997
4897297aa Front seal 1992-1997
03830109 Front seal 1990-1997
53021195aa Timing chain tensioner
Old Feb 15, 2009 | 04:31 PM
mini's Avatar
mini
same thing that is wrong with my truck. only i've got a high performance 360, and thought my timing chain was alright when i had it apart. bone head move because now it back fires because the lash is so big. a 20 dollar chain i cheaped out!.
Old Feb 15, 2009 | 07:54 PM
mikeinoregon's Avatar
mikeinoregon
it def. sounds like a loose timing chain. Does it do it at idle as well? When mine went bad, it rattled at idle as well as when the motor had a load on.
Old Jan 4, 2011 | 10:44 AM
hvnzent's Avatar
hvnzent
Exclamation rattle near belts/fan/pulleys??
My fiance has a 05 dodge truck v8 5.7, this morning he heard a rattling noise near the pulleys/fan area, after he took the belt off and tried to see what was loose he put it back on and the sound seemed quieter, it makes the noise in idle and accelerating, he pulls a dual axle trailer with heavy loads every now and then. I've done a little research and keep coming up with tensioner or timing chain. He has just over 100,000 miles. Any ideas? Thank you! Rachel
