Lift kit?
Old Jul 27, 2007 | 12:42 AM
vduballstar's Avatar
vduballstar
Default Lift kit?
I have a '95 and like to make it look a little more aggressive... and suggestions on lift? Coil?Body?Susp and links to where I can get parts
Old Jul 27, 2007 | 01:16 AM
peckens's Avatar
peckens
Default RE: Lift kit?
trailmaster has a body and suspension lift kit
Old Jul 27, 2007 | 02:07 PM
sykosollution's Avatar
sykosollution
http://www.4wheelonline.com/Products...ProductID=2433
here's one that I found that says it should work for our body style.
Old Jul 27, 2007 | 08:00 PM
vduballstar
Is there a cheaper way or product out there or do I suck it up and drop $1700 into my truck?
Old Jul 28, 2007 | 01:53 PM
peckens's Avatar
peckens
body lifts are cheaper but only lift the cab and the bed off the frame so your bumper will still sit lower and look goofy becasue they are attached to the frame unless you make brakets
Old Jul 29, 2007 | 05:10 PM
Countryboy0158's Avatar
Countryboy0158
that lift kit from 4wheelonline, is that for a 2wd model or a 4x4? would that work for a 2wd?
Old Jul 30, 2007 | 11:30 AM
peckens's Avatar
peckens
4x4, u wont find one for a 2x4
Old Jul 31, 2007 | 09:48 AM
sykosollution
I just want to throw out as a warning, I've been asking around about getting suspension lifts "professionally installed" apparantly with our style dakotas, it costs alot, because there's a buncha little adjustments that need to be made.
Old Jul 31, 2007 | 09:26 PM
codydakota's Avatar
codydakota
heard the same thing on the cost of lifts, very expensive for the 1st gens, I heard why, but can't remember now.
Old Jul 31, 2007 | 09:28 PM
codydakota's Avatar
codydakota
reminds me, you could adjust your torsion bars, good for maybe an inch or so, not too much though, then you can use blocks on the rear. friend did it on his '94 and it was noticably higher, but it wasn't anything you'd find in 4wheelin' mag either.
