CEL on with multiple codes
Old Sep 30, 2007 | 11:11 PM
dcorwin822's Avatar
dcorwin822
Default CEL on with multiple codes
1996 Dakota with CEL codes p0300, p0301 thru p0306 all came in with in seconds of having run the motor for 2 mins after resetting the light. It has a v6 motor. The crank sensor was replaced not too long ago (less than a month) and the CEL has been on sence. What would be some things to check? It seems to drive nice.
Old Sep 30, 2007 | 11:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: CEL on with multiple codes
Maybe its time for a tune up or the TPS sensor is causing your multi misfire codes.
Old Oct 1, 2007 | 01:59 PM
hemispheres's Avatar
hemispheres
Have a local parts store reset the CEL. If the problem resurfaces, pull the codes again andreplace the components which forced the illumination of the Check engine light.
Old Oct 1, 2007 | 06:11 PM
Nicegy525's Avatar
Nicegy525
What do the codes say is wrong?
Old Oct 1, 2007 | 09:59 PM
dcorwin822's Avatar
dcorwin822
lol i have my own code checker thing that connects up to a laptop...
I reset the light
reved the motor for 2 mins thrughout the power band and the CEL came on instantly
p0300 thru p0306
P0300- Multiple missfires detected
P0301- cylender one
P0306- cylender six
the part that went bad was Crank Pos Sensor and i doubt the truck would even start w/o it. I know most ford's wont w/o that sensor. My buddy at the local dodge chrysler what ever dealer**** wants me to check the CPS and the cap rotor and such.
Old Oct 1, 2007 | 10:00 PM
dcorwin822's Avatar
dcorwin822
what im really looking for is the shop book with wiring and some diagnostics info... anyone have some?
Old Oct 1, 2007 | 11:32 PM
Nicegy525's Avatar
Nicegy525
check the distributor cap and rotor usually if its a spark plug or wire, only one will go out first, not all of them. Where did you buy the CPS? If it was a cheapo aftermarket it could be faulty. Also check the ignition coil, it could be in the verge of going bad.
