replacement seats
Old Nov 29, 2007 | 12:30 PM
300hp318's Avatar
300hp318
Default replacement seats
did the 1st gen dakotas come with bucket seats? if so where can i get some?
did they have center console that would fold up to have seating for three?
thanks
Old Nov 29, 2007 | 01:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: replacement seats
I have a LE edition. they came with the drivers bench seat with themiddle seat and the passangers bucket. I belive the base modles came with both bucket seats and a center concle. But no middle seat. You could try junkyards. Or JCW.com does sell them too.
Old Nov 29, 2007 | 02:44 PM
300hp318's Avatar
300hp318
i have the base model 91 and it doesnt have bucket seats. its a single cab thats why i want the bucket seats with the fold up for a 3rd person.
Old Nov 29, 2007 | 02:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
what is your seats like?
Old Nov 29, 2007 | 03:02 PM
300hp318's Avatar
300hp318
a bench all the way across.
Old Nov 29, 2007 | 03:30 PM
fox's Avatar
fox
I have the same year andLE edition as you crazy and mine are both bucket seats with a center console in the middle.
Although could be cause your original truck was 2wd so maybe 2wd LE's had the third middle seat, where as the 4wd LE's had bucket seats.
Old Nov 29, 2007 | 08:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya it could be the 2wd. But ether way check junkyards they are the best way to go. Someone also said on here 2nd gen will fit on 1st gen with no mods. who knows.
Old Nov 30, 2007 | 10:18 AM
gr95dak's Avatar
gr95dak
Have a '95 SLTDak, standard cab, which had the (hard) bench seat. Replacedoem 95 seat with 60-40 '97 oem seats from an extended cab which have a center flip-up console. These seats are not a bolt-in, however, and require holes to be drilled and new bolts to be installed in the rear. However, with about a half-day's work and a little ingenuity, you can make them fit. These seats are high-back and will therefore protect your neck in the event of a rear-ender and are much more comfortable on long trips.
Hope this msg. helps.
Old Nov 30, 2007 | 10:25 AM
300hp318's Avatar
300hp318
thanks thats all i needed to know. i figure a junk yard in San Antonio will have what i need.
Old Dec 4, 2007 | 01:08 PM
partsman31523's Avatar
partsman31523
I PUT 2001 DAK SEATS IN MY 96 AND MY 96 HAD THE 2 BUCKETS AND I WENT TO THE 2001 SPLIT BENCH WITH THE FOLD DOWN CENTER CONSOLE / ARMREST BUILT IN THE SEAT BACK OF THE CENTER PASSENGER.
IT TOOK ME AND MY FATHER ABOUT 3 HOURS TO DO IT ALL BUT I TOOK MY TIME AND SHAMPOOED THE CARPET WHILE THE SEATS WERE OUT.
AS FAR AS MODIFICATIONS, EACH AND EVERY HOLE HAD TO BE RE DRILLED AND I USED NEW GRADE 8HARDWARE AND JUST RE THREADED MY OLD HARDWARE BACK INTO ALL OF THE OLD HOLES.
THE TWO OUTER FRONT HOLES CUTINTO THE FACE OF THE STEP UP IN THE FLOOR FOR THE 2 OUTER MOUNTS OF THE SEAT PEDESTALS ARE A BITCH! I WENT TO LOWES AND GOT SOME RETAINER STYLE BOLTS THAT GO INTO THE HOLE AND THEN PIVOT SO THAT THE ARMS OF THE "PIVOTING NUT" ,IF YOU WILL, STRADDLES THE HOLETHUS PROVIDES AN ANCHOR POINT AND TIGHTENED THE BOLT. IT'S HARD TO EXPLAIN SO I'LL HAVE TO TAKE A PIC AND POST IT.
ANY WAYS I ABSOLUTELY LOVE THE 2ND GEN SEATS IN MY 1ST GEN DAKOTA. THEY'RE A REAL HEAD TURNER FOR EVERYONE THAT GETS IN! PLUS IT'S DARKER AND HAS BLACK IN THE FABRIC SO WHEN I REPLACED MY HEADLINER I WENT WITH BLACK! TO THOSE WHO NEED A NEW HEADLINER I STRONGLY RECOMMEND DOING IT YOURSELF IT WAS SOOO EASY!!! PLUS IT GAVE ME THE OPPORTUNITY TO WIRE IN A LIGHTED GM REARVIEW MIRROR!!!
IM ME IF YOU NEED ANY HELP AND GOOD LUCK WITH IT !!!
