Anybody ever done this
Old Dec 3, 2007 | 11:12 PM
fox's Avatar
fox
Default Anybody ever done this
Anybody ever paint there intake manifold? I read in the mopar 318 book that its not recommend and it doesn't say why. Whereas my machinist says its not a problem.
Old Dec 3, 2007 | 11:41 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
Default RE: Anybody ever done this
It's no problem at all. Mind you, you'll need to use good high-temp engine paint to get it to last any amount of time. The manual might be talking about painting the entire thing, including gasket surfaces? That would not be a good idea.
Old Dec 3, 2007 | 11:57 PM
OneBadKota's Avatar
OneBadKota
Painting it isn't a problem. I would recommend powder coating it though, it will last longer.
Old Dec 4, 2007 | 11:09 AM
blue95's Avatar
blue95
Don't clear coat it: it turns yellow. Even if the can says it won't; it will.
Tape over the gasket surfaces, injector holes, and vacuum connections.
Old Dec 4, 2007 | 03:14 PM
fox's Avatar
fox
ya im probley not even gonna prime it just spary some glossly black on there I figured not to paint gasket surfaces and injector hole, when im done it gonna look goooood[sm=shades.gif]
Old Dec 4, 2007 | 03:16 PM
300hp318's Avatar
300hp318
on my 318 i built i sand blasted the intake than put a clear coat on to put a little shine to it.
Old Dec 4, 2007 | 07:35 PM
jonnymagnum's Avatar
jonnymagnum
I would get it powder coated. it will last along time.
Old Dec 4, 2007 | 10:54 PM
flyers win the cup's Avatar
flyers win the cup
clear coat does yellow at high temps, espically right around were the intake meets the block, forget about it it will cause problems in the long run. looks pretty before you start it, but's it's all downhill from there.
get pro's to paint it ( powdercoat ).
