96 and older exhaust ?? any sound bytes also
Old Dec 5, 2007 | 03:25 PM
Dakota_Don's Avatar
Dakota_Don
Default 96 and older exhaust ?? any sound bytes also
how did you run your true dual exhaust? it looks pretty tight around the tank? Pics would be great.
and anyone with sound bytes, and what type mufflers did you use?
Old Dec 5, 2007 | 03:45 PM
durangeddurango's Avatar
durangeddurango
Default RE: 96 and older exhaust ?? any sound bytes also
to do this the easiest way is to build the true duals is to run them down the passenger side(factory routing) then use a dual in dual out muffler then connect the tails. pm me for the bend cards.i have the bend cards for the systems that I have built. if you have access to a bender and a counterclockwise rotation dial i can email the bend card to you.
Old Dec 5, 2007 | 05:20 PM
BAnders's Avatar
BAnders
a dual in/out muffler isnt dual exhaust.... 2 pipes & 2 mufflers, mine run down pass. side then 1 pipe around the left side of the spare tire and out the rear
Old Dec 5, 2007 | 05:34 PM
jonnymagnum's Avatar
jonnymagnum
my 88 just has a flowmaster 40 dumped before the axle. soon it will be two 4 or 5" stacks outta the bed
Old Dec 6, 2007 | 12:09 AM
OneBadKota's Avatar
OneBadKota
I just realized I already replied to this on another site. [:-]
Old Dec 6, 2007 | 12:20 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I dont have duel exhast but I do have a flowmaster 40 3in and a hollowed cat. check it out http://www.youtube.com/watch?v=es4S1qaqq6g
Old Dec 6, 2007 | 12:31 AM
95V8Dakota4x4's Avatar
95V8Dakota4x4
Mine sounds pretty mean with just a 40 series with a dump in place of the factory muffler.
Old Dec 7, 2007 | 02:05 AM
milky9788's Avatar
milky9788
how big of piping did you plan on running?
Old Dec 7, 2007 | 03:59 PM
Bad96_3.9's Avatar
Bad96_3.9
there are videos of a few burnouts when i had the single in dual out and cat on myspace, i down have and with the flowmaster aand no cat yet... it is a v6 though, so it does not sound to good to me!
Old Dec 8, 2007 | 12:53 AM
milky9788's Avatar
milky9788
i have 40 series flowmaster dumped before the rear axle and hollowed out cat and it sounds really mean...if you can take the cat off and hollowed it out because it only takes a few minutes and its a easy performance upgrade
