91 dak front speakers
Old Dec 13, 2007 | 10:54 PM
daksport91's Avatar
daksport91
Default 91 dak front speakers
91 dakota reg cab
one of my fronts sounds shot so im in the market for a new set of speakers... havent looked at them yet... what size are they and the big question im asking.... mounting depth... what do i have for mounting depth room in the doors??
thanks
p.s - out of curiousity whats in the back for speakers and how much magnet room is there
Old Dec 13, 2007 | 11:20 PM
partsman31523's Avatar
partsman31523
Default RE: 91 dak front speakers
fronts are 5.25" and I'm not sure what the depth is but I installed a set of pioneers and there was no trouble at all! Just keep the plastic buckets installedthat mount behind the speakers. They give them better low frequency sound like they're in a speaker box!
I saw on www.crutchfield.comthat we have 5"X7" speakers in the rear. here's the link! http://www.crutchfield.com/App/Produ...?g=400&l=J&
Old Dec 13, 2007 | 11:25 PM
daksport91's Avatar
daksport91
thanks, id still like to find out deep i can go without pulling the speaker out to check....
Old Dec 14, 2007 | 11:18 AM
iraqvet's Avatar
iraqvet
I got a set of 6" speakers to fit in my 93 doors with not cutting. The doors on the Dakotas are pretty deep, but if you are worried about it, pull the panel off and check....you have to remove the door panel to replace the speaker anyway.
Old Dec 14, 2007 | 03:38 PM
92BLACKLS's Avatar
92BLACKLS
I put some 6.5" speakers from target that I believe were mispriced for $6 so I bought em, turns out they were for $25 but anyways I took of the plastic covers and put the in the door, its a 3 peice speaker to so the door cover kinda doesnt fit flush but it added a lot more low end sound and the windows go down just fine, nothing hits.
Old Dec 14, 2007 | 07:01 PM
daksport91's Avatar
daksport91
im askin this topic because i dont want to pull the panels off until i have a set of speakers......because then either the door has no panel for a couple weeks or i have to put it back on again then take it off when i get the speakers...... and i plan on just staying stock size of 5.25
ORIGINAL: iraqvet
Old Dec 15, 2007 | 10:13 PM
put it to the floor's Avatar
put it to the floor
the door panel is very easy to take off and put on ... and checking the depth ....everything shouln't take anylonger than like 5-10 min. i can do mine in just a couple minutes also with my truck they put some extra room in the door for the speaker(it has infinity speakers) but when i got a new door for it ,it wasn't set up for it and i hit the window so i had to rig up another speaker(oxford)
Old Dec 16, 2007 | 12:23 AM
92BLACKLS's Avatar
92BLACKLS
yea its really easy to do specialy with stock speaker sizes, I even cut in from some tweeters, **** sounds really good!
