how much fluid?
Old Dec 19, 2007 | 01:55 AM
oglejust's Avatar
oglejust
Default how much fluid?
alright i have an 87 dodge dakota 4x4... how many quarts of tranny fluid does it take if i do a complete flush? im talkin unhook the cooler hose and flush it. also how much does each differential take?
Old Dec 19, 2007 | 03:51 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: how much fluid?
My book says 1.75gal of coolent. the diff. 1.25quarts.
Old Dec 19, 2007 | 12:10 PM
iraqvet's Avatar
iraqvet
Transmission and transmission cooler flush? I can't find anything in the book on capacities, but when I replaced my engine, I drained the torque converter and transmission....those alone took over 6 quarts.
Old Dec 19, 2007 | 07:50 PM
dodgerules86's Avatar
dodgerules86
Tranny fluid - a dry fill takes about 11 quarts. When I flushed the transmission in my '96, I used about 15 quarts. Just run it through until the fluid looks clean, and than a few extra seconds. (Keep in mind, these transmissions don't move the fluid in Park, so a helper is very nice).
Make sure you check your fluid level very good after your done.
Differential varies on which one you have, about 1.5 quarts for the 7-1/4, about 2.25 quarts for the 8-1/4.
Transfer case, probably around 1.25 quarts.
Typically, just fill the transfer case and differentials until the fluid starts pouring out the fill hole.
Old Dec 19, 2007 | 08:46 PM
oglejust's Avatar
oglejust
well what if i just change the fluid in the pan and change the filter... will that help extend the life of the tranny?
Old Dec 19, 2007 | 09:09 PM
kahanabob's Avatar
kahanabob
Only about a quart in the pan, flush it.
Old Dec 19, 2007 | 09:41 PM
dodgerules86
There is about 3-5 quarts in the pan. Most fluid is kept in the torque convertor.
There is some fact to the "if your transmission hasn't been regularly serviced before, don't start now," but it seems to be a little hit or miss.
Old Dec 19, 2007 | 10:42 PM
oglejust's Avatar
oglejust
alright ill do the total flush
Old Dec 23, 2007 | 09:04 PM
oglejust's Avatar
oglejust
well today i changed the fluid in the rear diff. and it wasnt as easy as i thought... hopefully ill get to the tranny next weekend
