Fuel Tank Size
Old Feb 1, 2008 | 01:38 PM
memasterac's Avatar
memasterac
Default Fuel Tank Size
This question bothers me for a long time. I know the Dakota has either 15 gal or 22 gal gas tank. My 92 Dakota, however, I know it does not equipt a 15 gallon tank because the most I can fuel is around 17.5 gallon. Does it mean I have a 22 gallon gas tank? I can never put in more gas than 17.5 gal so where is the remaining 4 plus gallon? I know this question sounds dumb... oh well.
Old Feb 1, 2008 | 01:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: Fuel Tank Size
ya you probly do have 22gal. our gauges are not completely accurite. I can literaly run under empty for 3-4 days.
Old Feb 1, 2008 | 01:47 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
No you have the 15 gal tank. My 93' was the same way, I think ithas a factor of safety incorporated in the design.
Old Feb 1, 2008 | 02:03 PM
cessna2004's Avatar
cessna2004
If I would have to guess I would say that you have a 15-16 gallon tank. Most tanks have an additional amount of space for fumes. My Avenger has a 16 gallon tank but I can but almost 18in. Before you fill up again run as close as you can to empty and see exactly how much gas you canput into the tank.
Old Feb 1, 2008 | 10:10 PM
capricorn's Avatar
capricorn
New Member
I have the same problem. When the low fuel light comes on I can only put in about 18 gallons. That is as low as I let it get though.
Old Feb 3, 2008 | 12:19 PM
mattg's Avatar
mattg
i put in a new fuel pump a few months ago and didn't install it correctly. since it's cold out i haven't had the time or interest in fixing it, but i installed the pump wrong and the low fuel light and gauge always read empty.
i've run it dry on more than one occasion and i put in 22 gallons.
Old Feb 3, 2008 | 05:26 PM
mini's Avatar
mini
around 90 liter on mine, whatever that is in gals
Old Feb 3, 2008 | 05:29 PM
codydakota's Avatar
codydakota
sounds like 15 gal tank to me as well
