Help! Weird electrical problems
Old May 27, 2008 | 09:55 PM
CSXfan's Avatar
CSXfan
Default Help! Weird electrical problems
I noticed that my left hand blinker doesn't work anymore. Both the front and rear bulbs turn on but they do not flash. Every once and a while they will flash, but it doen't happen very often.The LHindicator light on the dash turns on, but it doesn't flash either.
Also, when I have my parking lights or headlightson my LHtaillight doesn't work. The running light comes on with the headlights but when I step on the brakes everthing goes black. When I don't have my parking or headlights on the tail light works fine. Cananyone explain why thisis happening and how I can fix it?
Old May 28, 2008 | 01:14 AM
88dakv6's Avatar
88dakv6
Default RE: Help! Weird electrical problems
first thing is to check the two flashers, make sure they both work, on my 88 the blinkers and the brakes are routed trough the combination switch wich is no more than the blinker switch... just tell me the year of your truck and ill get you the flasher/brake/hazard diagram.
Old May 28, 2008 | 08:04 AM
CSXfan's Avatar
CSXfan
I always seem to forget the important info, its a '94 4x4 with a 3.9. Thanks
Old May 29, 2008 | 08:45 PM
88dakv6's Avatar
88dakv6
i got the diagram i will scan it and upload it shortly
Old May 29, 2008 | 09:08 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a wiring diagram for a 96 everything should be the same
http://www.mitchell-auto.ru/UserFile...-dakota-wd.pdf
Old Jun 4, 2008 | 10:28 PM
CSXfan's Avatar
CSXfan
Thanks for the help guys. I can't figure out the wiring diagrams though. I don't know what wires I should be checking. PS, when I hit the hazard button on the column, both blinkers flash like normal so I don't think it's the flasher modual.
Old Jun 6, 2008 | 03:18 AM
johndakota's Avatar
johndakota
look on fire wall for a plug with a boot on it attached to the wireing harness on the drivers side under the hood dodge is know to have corrosion and eventully breakage the connetion between the wire harness and plug ill have pics up i had same thing happen but the possitive to my blinkers headlight and brakes didnt work becuase of this try it out ill have pics of wat happend to mine and see if its th same for u
Old Jun 6, 2008 | 01:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I had the exact same prob. with a 2000 chevy van a couple weeks ago and it was the directional multi switch on the colunm. On this vehicle (dakota)the switch is about 80 bucks.
Btw, do you have a trailer plug in the back ? If you do make sure none of the wires are rubbing on the frame.
And there is a chance the headlight switch is bad! About 25 bucks, But you got to check all the wires (power and ground) and connectors before wasting money on parts.
Old Jun 28, 2008 | 08:05 PM
SLT Dakota's Avatar
SLT Dakota
I had a problem all most like it no head lites no radio vollum trns worked 4 ways worked tach quit corossian do you live in salt country. abs lite on. fix all but abs. salt on roads. i found 95dakota has sepret wireing iside cab . computer run engine abs computer abs system my problum is finding where abs computer pick up power. the clean wire plug corrusian from plug from engine compartment to (croussian eat power lead to head light switch a burn up switch. you wouldn't belive what goes thrrough that switch. see there i no fuse for abs under hood or in fuse box. what year is your truck my was the rubber boot side peel back boot check an clean plug prongs .
