318 swap advise on a 91 dakota
Old Jun 9, 2008 | 07:17 PM
LowClassicDC's Avatar
LowClassicDC
Default 318 swap advise on a 91 dakota
im just wondering if 1991 wire harness is compatible with a 91 dakota wire harness from a 3.9L, or if i just have to change it all out to the wire harness from a 318
Old Jun 9, 2008 | 07:39 PM
Truck Dude's Avatar
Truck Dude
Default RE: 318 swap advise on a 91 dakota
idk, but my guess is that you would have to switch it.
tell me if im wrong guys!
Old Jun 9, 2008 | 09:04 PM
LowClassicDC
yeah im assuming you have to, but im not to sure, i just picked it up not to long ago and that 3.9 has to go haha
Old Jun 9, 2008 | 11:26 PM
fox's Avatar
fox
different engine different harness
Old Jun 10, 2008 | 12:47 PM
LowClassicDC
thanks for the advise
Old Jun 12, 2008 | 01:46 PM
Bad96_3.9's Avatar
Bad96_3.9
not sure with the tbi engines, on the mpi engines all you have to do is add two more injector wires, try looking at a wiring diagram for it and see whats different between the v6 and v8 trucks.
Old Jun 12, 2008 | 07:31 PM
LowClassicDC
thats what iv been looking for and i havn't found anything on it yet, but i figured if its tbi then it would work and maybe run a few new wires from the fuse block, but if its just less of a pain to swap harness's then thats what ill just do, i have a 318 and a 360 with the tranny and both harness's, and if i can stuff the 360 in it then im going to
Old Jun 15, 2008 | 12:20 AM
injmopar's Avatar
injmopar
On a dakota a 91 is TBI,why would you have to change the harness.Just change the computer,and use the distributor the comes with the v8. As was pointed out if it was a 91 ram you would need to add two wires with the computer
Old Jun 15, 2008 | 08:28 PM
LowClassicDC
thanks man, thats exactly what i thought, ill give it a shot
