Transmission removal tips/tricks
Extension, no just a really long flexible arm that you don't mind getting greasy.
There are5 bolts up top that go from the tranny to the engine blocktheir a 9/16 i beileve I used a box end wrench to lossen them up. Then there are to 2 more bolts that go from the block to the tranny,they arelike a 1/2 inch longer than the other 5,they are located on the corners of the block, probley got crawl underneath the truck to see them.
here a photo of wut I mean.
Attachment 117551
Attachment 117551
Righty tighty, lefty loosey.
For trans bolts with 'limited access', I remove the rear cross member, support the end of the trans on a jack, or something similar, lower the trans down so I can get a shot at the trans bolts with a long extension, and a wobble socket. It's actually almost 'easy' that way. (an impact wrench makes it even easier..... but, does give you the ability to toss bolts a GREAT distance once they come loose.
