94 Dakota, rough idle...stall
Old 06-29-2008 | 01:15 PM
pghstarsky's Avatar
pghstarsky
Default RE: 94 Dakota, rough idle...stall
If the cat was the problem, why would it only occur after the engine heats up?
Old 09-22-2010 | 09:09 AM
lpfdfire's Avatar
lpfdfire
I have a 94 Dodge Dakota v6 2wd. It is stalling as I take off from a stop or on a hill. Any ideas?
Old 09-22-2010 | 09:28 AM
sammatthews2007's Avatar
sammatthews2007
I ended up changing my air filter gasket and idle air control, and that solved the issue for me.
Old 01-02-2024 | 06:48 AM
aaron290698's Avatar
aaron290698
Default What worked for me.
check your transmission fluid, to old or to low will cause this to happen, I couldn't find the source at first but came across it when changing all fluids, hasnt done it ever again after i changed my transmission fluid.
Old 01-02-2024 | 07:55 AM
bronze's Avatar
bronze
Their post was 14 years old so I suspect he found the problem or the problem found somewhere else to go.
The following users liked this post:
tndakman (01-02-2024)
Quick Reply: 94 Dakota, rough idle...stall
