I am really hurting for some help :(
#21
on
1 Post
When you're speed sensor was acting up, can do help me out and be specific about all the symtoms? After doing the transmission swap in my truck, I'm now using the speed sensor thats in the new-to-me transfer case. Ever since then, my truck has acted like it wants to stall when I push the clutch in and let the rmps fall to idle. I replaced the IAC twice already (the second one on warrenty of the first one) and it has fixed the problem for a week or two and it keeps coming back. My cruise control does not work either, but I was thinking that could be related to the park/neutral saftey switch being grounded perminantly now. I haven't had time to look into that switch yet, but I'm starting to wonder if there a problem with my new speed sensor. The only reason I would think its fine is because the speedometer works great, and our year trucks don't have the seperate speedometer cable like the '93 and older did.
#22
I am going to do a little straightening up in my garage tonight, then I am going to remove the vacuum line from the transfer case and engine and see if I can find any breaks in it.
#23
I don't know what it is on my truck, cause unlike yours, my speed sensor controls the speedometer, which has never failed. The other thing I'm thinking of is the EGR has gotten too bad, cause the CEL has been on for the EGR since I got the truck. I'm about to take care of that though... I got a set of headers with no EGR tube, and I have that '98 intake manifold that came off the 360 that I'm doing the kegger mod on and then I'll install both, which will get rid of the EGR for good.
Is there really a vacuum line between the engine and transfer case on your truck? On mine there is just a breather tube that stops up near the engine.
#24
Yeah there sure is. Its just a rubber hose that is pinch clamped to a port on the transfer case. I got to know it very well when I replaced this transfer case a month or so ago.
So your truck doesnt have an EGR? The EGR was actually the first thing that I thought that it could have been. But if you are having similar problems but dont have an EGR then I can scratch that off.
I called the local dodge dealership and he first suggested running some fuel cleaner through the engine. I then stated my problem and that I thought it might be vacuum related. He said yeah, we need to put on a vacuum gauage to see if its even holding vacuum. I told him I thought it was as there is strong suction at both the PCV valve and the crank case breather filter. He was stunned then and couldnt come up with any quick fixes. I told him that I tried replacing the IAC, and while that has helped prevent the truck from dying that its still an issue and there are no error codes to be had just 55 for end of codes or clear. He then said that there were no TSBs for this issue and that if I were him he would take the throttle body off and clean the carbon build up on the butterflies where it seats against the casing and cuts off the air.......I was stunned by his apparent lack of troubleshooting skills and told him it wasnt related to idling all the time, only idling in gear. In nuetral gears it idle beautifully. He said, "Yeah, clean that throttle body, thats where I would start".
I am getting so frustrated.
#25
That always pisses me off when the guys who work at dealerships can't help. See mine is opposite of yours... it tries to stall when I push the clutch in and put it in neutral when I'm coming to a stop, catches itself, and then idles fine after that. My truck does have an EGR right now, I was saying that I'm getting rid of the EGR by using headers and an intake manifold that don't have it.
I know there is a hose on the transfer case, but follow it all the way up and I'm convinced it's not a vaccum hose. It's just a breather that they put way up in the engine bay to get it as high up as possible so you don't flood the transfer case with mud if you go through deep mud. I know the older 1st gen dakotas had a vacuum actuated front axle disconnect, so unless that vacuum goes through the transfer case and then to the axle, there should be nothing vacuum controlled in the transfer case.
#26
#27
I couldnt trace exactly where that hose came up and connected to so I took a guess at the transducer after looking at some of the diagrams in an older parts manual.
#28
#29
They dont in Kansas, but they do in Missouri. And in my line of work and current location, its very possible to end up working in missouri else I would.
If clean the egr betters the problem I will probably spend the 100 bucks to get a new liftetime warrantied egr valve from oreillys and end this nightmare.
