trans gear ratio
Old Apr 27, 2009 | 10:52 AM
razor rc's Avatar
razor rc
Default trans gear ratio
i was wondering what the gear ratio is for a 87 v6 auto trans w/ 4wd. im trying to figure out my final gear ration for my truck is.
Old Apr 27, 2009 | 12:16 PM
95_318SLT's Avatar
95_318SLT
Being an '87 v6, you should have the A999 (32rh) transmission. Here is what I could find about it from allpar.com (you should check out that site, it has tons of info)...
The various Torqueflites had the same internal ratios, despite their other differences. Until 1980, they were relatively narrow (see Tom Hand's detailed article); in and after 1980, a wide-ratio gearset was introduced and used in most of the 998 and 999 transmissions. This ratio was 2.54 in first, 1.54 in second, and (as with the earlier Torqueflites) 1.00 in third. This gearset, which uses a welded-steel planet cage, is noisier and less durable than the original-ratio gearset with its machined-aluminum planet cage, but the lower first and second gears helped cope with the tall rear axle ratios needed for gas mileage.
Your transfer case should be the NP207, which has a low range of 2.61:1 and a high range of 1.00:1
Old Apr 27, 2009 | 02:41 PM
razor rc's Avatar
razor rc
thanks 95_318SLT. I do have the 207 but its actually 2.72:1
Old Apr 27, 2009 | 02:51 PM
95_318SLT's Avatar
95_318SLT
Yeah, you're right... the jeep version of the 207 has the 2.61:1 ratio, but I guess the dodge version has the 2.72:1.
Old Apr 27, 2009 | 10:54 PM
ZackN920's Avatar
ZackN920
Would that be the same for mine even though its 2 WD
Old Apr 27, 2009 | 10:57 PM
95_318SLT's Avatar
95_318SLT
Yes, the transmisison ratios are the same, minus the transfer case.
Old Apr 27, 2009 | 10:59 PM
stesul411's Avatar
stesul411
YES, same for 2wd and 4wd, for that matter it's the same for all 904 based transmissions
Old Aug 1, 2013 | 02:55 PM
hilljack1987's Avatar
hilljack1987
What would the axle ratio be? I have the same truck as razor rc, a 1987 dakota 4x4 auto 3.9, and it feels like the engine is running a million rpms at 65 mph and my foot is pretty much on the floor to get it there. it is all stock except for 31x10.50 tires
Old Aug 1, 2013 | 06:32 PM
rx7_dude2003's Avatar
rx7_dude2003
There are tags on ur diff cover bolts it could be either 3:55 or 3:90 ratio
Old Oct 15, 2013 | 01:13 PM
hilljack1987
I looked, but there aren't any tags :/
