Eletric Fan?
Old Jun 24, 2009 | 11:15 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by Bad96_3.9
just mounted my intrepid dual fans up. got a 3 position switch going to to relays so i got low and high, i am just going to leave it on low most of the time, and switch to high on days like today when he a/c is needed
Do you have some pics on how they came out? How did you mount them up was it easy? Did you need to fab up brakets or anything? Does it cover them up completly? I just wanted to know incase mine ever die out. The junkyard is much cheeper than new units.
Old Jun 24, 2009 | 12:16 PM
Bad96_3.9's Avatar
Bad96_3.9
i will take some pics and post them up today
Old Jun 24, 2009 | 08:52 PM
Bad96_3.9's Avatar
Bad96_3.9
here they are, as you can see i have to remove the belt to get it in there, it is actully upside down compared to how it was in the intrepid, but fit the radiator perfect!
Old Jun 24, 2009 | 09:29 PM
ZackN920's Avatar
ZackN920
I was wondering. . . . . .
What fan from the junkyard or even new could be put in my Dakota after i get a 318?
Old Jun 25, 2009 | 12:52 AM
Bad96_3.9's Avatar
Bad96_3.9
you will have to do the swap to see, there are 1000's of sizes to choose from
Old Jun 25, 2009 | 01:05 AM
ZackN920's Avatar
ZackN920
Yea but it would have to fit in front of the radiater and behind the air conditioner's smaller radiater (dont know what its called), i dont know how much space there is but i think theres at least 2 inches, probably more
Old Jun 25, 2009 | 01:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Looks good Bad96. And how is it mounted?
For a list of fans that are known to fit. Check the FAQ2.
Old Jun 25, 2009 | 02:00 AM
Bad96_3.9's Avatar
Bad96_3.9
there are little tabs where it is mounted on the car that fit over the metal coming from the sides of the radiator. drilled some holes and screwed it up there. i dont do the pull trough radiator things
Old Jun 25, 2009 | 08:25 PM
miniderblank's Avatar
miniderblank
So is there a secert way to take the fan of to put the eletric one on
Old Jun 25, 2009 | 09:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Just remove the Giant nut that holds it on the water pump. It is regular thread and it is something like a 34mm wrench. And to hold the pump pulley it is best to get a special tool. Lots of posts on the tool. You can try doing a search or I may have put it in the FAQ2 section.
