Eletric Fan?
Old Jun 25, 2009 | 11:06 PM
  #21
Bad96_3.9's Avatar
Bad96_3.9
i put some bolts in the little holes and wedge a pry bar in there. but the best thing i have used is an air chisel, it works reat and its quick!
Old Jun 18, 2010 | 02:29 AM
  #22
Deerkiller9991's Avatar
Deerkiller9991
so how would you do this? is the stock fan just bolted on so you can remove it? and would you have to make shrouds or could you use the ones that are with the electric fans?
Old Jun 18, 2010 | 11:17 AM
  #23
Crazy4x4RT's Avatar
Crazy4x4RT
The stock mechanical fan is bolted to the water pump. It is one large nut. Remove that.
As for a shroud with the new fan depends on what you get. If you get one with a shroud your okay. If you don't get a fan with a shroud you will have to make one for optimum air flow.
