Eletric Fan?
Old Jun 20, 2009 | 11:05 PM
miniderblank's Avatar
miniderblank
Default Eletric Fan?
I Just bought a dual fan from my local pick a part off of a Dodge Intrepid. I was wondering how everybody has theres wired I.E. wiring, relays, switches?
Old Jun 21, 2009 | 12:04 AM
Blue 12's Avatar
Blue 12
I have mine wired with a relay on a toggle switch. i wired my buddys chev with a relay and a switched pos signal(ie turn the key on and it will trip the relay so he doesnt have to remember to flip a switch). i think the best way would be to get a temp sensor that would trip a relay at a preset temp
Old Jun 21, 2009 | 01:08 AM
95_318SLT's Avatar
95_318SLT
+1. I prefer this way to a thermo switch so that if I take the truck offroad to play, or if its a really hot day, I can leave the fan running all the time and never worry about it overheating. Also, I've gone entire short trips across town never turning the fan on, which saves putting a load on the alternator.
Old Jun 21, 2009 | 01:41 AM
Hahns5.2's Avatar
Hahns5.2
I've seen it done with a 3 way switch and a thermostat, you you can set it to use the thermostat, full time on or totally off. That's how I would do it.
Old Jun 21, 2009 | 11:37 PM
dbilik's Avatar
dbilik
I would go thermal switch if it were me and I had a dual fan unit.
I have two fans and a sheet of aluminum I am going to weld up into a shroud. One fan will be run with a thermal switch and one with a switch in the dash.
Old Jun 22, 2009 | 05:01 PM
ZackN920's Avatar
ZackN920
I agree, id probably go with that once i get a 318 so i can go with it off if its not hot out or if i want it to warm up fast, on a thermo mabey for highway and more and manual switch for hot days or whenever i want it to run cool
Old Jun 23, 2009 | 01:01 AM
1shotjake's Avatar
1shotjake
hmm how necessary is said shroud? I was thinking of just using a generic fan from summit similar to the direct fit one, but the install just comes with ziptie like connectors. Can I just use those, or will it not be efficient enough w/o the shroud?
Old Jun 23, 2009 | 10:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I think the shroud is not necessary. But if towing or hauling you want your radiator to cool 100% of its body. Not 70% or so with out the shroud. What I did was take off my radiator and mounted the fans. Then got some simple sheet metal and make the corners.
Old Jun 23, 2009 | 11:37 PM
dbilik's Avatar
dbilik
+1 on the shroud. I would add it or fab up one.
Old Jun 24, 2009 | 01:47 AM
Bad96_3.9's Avatar
Bad96_3.9
just mounted my intrepid dual fans up. got a 3 position switch going to to relays so i got low and high, i am just going to leave it on low most of the time, and switch to high on days like today when he a/c is needed
