need a ? answered
Old 07-25-2009, 08:54 PM
willeox's Avatar
willeox
willeox is offline
Default need a ? answered
ok so when i use to do burnouts it was just the passenger side that would spin, well the next time i did one both sides would spin, and just today only the driver side would spin, is this something that is suppose to happen?
Old 07-25-2009, 09:01 PM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
If you have an open differential or worn out limited slip differential then yes, that is normal behavior.
Old 07-26-2009, 12:50 AM
RockGuardedDak's Avatar
RockGuardedDak
RockGuardedDak is offline
if its a 4x4 with a 3.91 ratio, then its a worn out limited slip. but if its a 2WD with a 3.55 ratio, then its an open diff.
when i do burnouts, more often than not (depending how hard im holding the brakes) both wheels spin. one usually spins faster than the other. but i have a 2WD with a 3.55 ratio. mines an open diff. when i spin the tires around a corner, only one spins. with limited slip, both will spin around corners and will cause the truck to kick out.
Old 07-27-2009, 12:49 AM
ZackN920's Avatar
ZackN920
ZackN920 is offline
I hate having one spin on the corner because thats just tellin me im not getting good grip and theres a good amount of streets with gravel or sand on the corners, sorta cool though when i want to in the rain because there both spinning most of the time, hopefully mine just has a worn limited slip, though i found out with a label i have that the truck came with a 2.94 ratio, Does anyone know any info about that one if it only came with limited slip or only open?
Old 07-27-2009, 12:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Well actually none of the ratios ONLY came with the LSD. It was an option on all. Trust me I did search when I was looking for a 3.9 ratio rear end. I found several and all were damaged in some way so I didn't get them and none had a LSD. Just lift up the rear end, with both tires off the ground spin one tire. If the other spins in the opposite way then it is a Open diff. If it spins in the same direction then it is a LSD. And my info shows the dakotas didn't come stock with a 2.94. Ratios: Dakotas came with 3.21, 3.55, or 3.90.
Old 07-27-2009, 01:02 AM
ZackN920's Avatar
ZackN920
ZackN920 is offline
Huh, i have a peice of paper from 87 that says mine does but,... i dont know
Old 07-27-2009, 01:09 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Well if it is an official paper from dodge I guess you do. The early years are hard to get info on.
Old 07-27-2009, 01:15 AM
ZackN920's Avatar
ZackN920
ZackN920 is offline
Yea your right about that!
That also reminds me why are there so many posible and inexpensive upgrades and aftermarket products for the LA 318 but not the LA3.9 if there just 2 cyls cut off a 318, is it because it was only around for like 4-5 years or what
Old 07-27-2009, 01:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It is because it is a 6 cly and the demand for v6 parts then and now was never high. No one wants to make upgrade parts for something that will only sell a few here and there. I'm not sure how long the LA 3.9 was in production but I'm sure it was not 4 or 5 years.
Old 07-27-2009, 01:36 AM
ZackN920's Avatar
ZackN920
ZackN920 is offline
Actually it was, the first year they were carbed but 88-91 they were TBI
Quick Reply: need a ? answered
