Body Lift and Torsion Crank questions
Old 08-12-2009 | 08:24 AM
dakota33's Avatar
dakota33
Originally Posted by '95Dakota
o right, he's got 31's, i forgot. I love the look of Dakota33's truck. He's got th same but with 33's. I just dont have enough money for 33's lol 250 a tire, plus i want 16 or 17" rims so i need more money for rims. I have 31" BFG M/T's right now so those will be fine til i get the money for 33's.
but from the change from a 31" to 33" isnt too much money.. your best off saving till you have enough.. and then do it that way.. just to let you know though, if you go with a 16" or 17" rim, your going to pay alot more for the tires... as I found out haha. But its all good.. they do look alot better then little 15s
and, Im wanting to upgrade to 35" tire.. I know I can do shackle flip for rear.. but anyone? does anyone know what I can do for the front lol.. Im looking for something cheap.. not a straight axle or anything like that.. to hard to find. Does anyone know if its possible, but easily done to push the front axle ahead 1-2".. cause the main clearance problem im worried about is the back of the front fender.. and you cant cut into that because of the body mount.. but if needed you can cut into the front of the front fender. Because I know even the way my truck sits now, I can fit 35" on the back no problem.
Old 08-12-2009 | 10:49 AM
skyshark186's Avatar
skyshark186
i suppose It depends on what you plan on using it for. My suspension up front is basiacally useless right now. Sure it will flex down, but not much and it will eat parts as it does it. As it sits it can flex up maybe a 1/2 inch.
Im not rock crawling or anything like that, but this is what Im looking at. Around here you can get dana 44's for 100-150 bucks complete with springs and steering arms. It will cost me maybe 30 bucks for steel to make my shackle hangers. Throw in some random unexpected parts for 100 bucks or so and Im at 250-300. Now look at it this way. My current axle needs a CV for at least the passenger side. Thats 60 bucks. I need all the tie rod ends replaced. To get decent ones thats easy 80-100. Then ball joints, for another 120. So to me its cheaper to do the swap.....but maybe not to others.
Moving your axle foreward would be nearly impossible. Thats not correct to say.....it would require TONS of fabrication. You would have to move your crossmember foreward the same amount so your tortion bars would stay at the same geometry. Redo all your mounts for your A arms. ......it wouldnt be fun.
Also Im going to trim the back of the front fender. Mine are rotted anyway. The body mount shouldnt bother anything.
Old 08-12-2009 | 11:25 AM
dakota33's Avatar
dakota33
where abouts are you located?.. I cant find any dana 44s anywhere.. and btw what would these be out of?.. would it take much work to swap it in?... but no luck with finding them around here..
Well I guess skip the idea about moving the front axle forward..
but about the front fender you will see what I mean when you start cutting the fender.. its really close.. and with a big tire, Its easy to hit that.. but I need to bring that front up more.. if I stay with the v6, the v8 torsion bars I heard will bring it up a little?
Old 08-12-2009 | 11:30 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya using V8 bars will lift a V6, but if you already got the lift keys you probably got the control arms maxed out and wont be able to lift up more. I got the 33's too, with enough room for 35's. With BFGR A/T the difference in between 31's and 33's is $20.
Old 08-12-2009 | 12:17 PM
dakota33's Avatar
dakota33
hmm, ya i dont think its worth trying then.
hey crazy.. where did you get the fron push guard for your truck?.. Its probly custom made to fit eh? I had an older dakota that i made an S10 one fit.. had to get it stretched wider but looked great.. just cant use it.. cause it took its fair share of rocks lol.. but now looking for something to support my lights.
Old 08-12-2009 | 12:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya I custom made my own push bar. I just found one off an old ford and cut it up to fit it and welded it up. Just check the JK or even craigslist or ebay. Very easy! But you can buy some grill guards. Check the FAQ2 for the links.
Old 08-12-2009 | 01:15 PM
dakota33's Avatar
dakota33
alright thanks for the help.. But couldnt find even one light bar from any of those sites.. only one I did was on ebay, and that was awhile ago.. they dont have any listed atm
Old 08-12-2009 | 01:28 PM
'95Dakota's Avatar
'95Dakota
Terra Grap's are just over $1,000 to get them up here from 4WheelParts. I got a quote from the Kal Tire here and its $1,200 for tires and mounting and balancing.
I'm likin the Hankook Dynopro M/T, im gunna go to the tire shop and get a quote on them.
I see what you mean with the 16 and 17" tires. But my pro paid $275 a tire for 33x12.5x15 Toyo M/T's so its pretty much the same price, if not a little bit cheaper then him for being a 15".
Does anybody know what offset those 2nd gen rims are? They seem way more offset then the 1st gen, probly cuz they are lol or does 95 318SLT have spacers?
Old 08-12-2009 | 01:35 PM
skyshark186
RIght now Ive got a body lift and around 3" of suspension lift. Heres what it looks like with 31's. I dont like it. Ill be picking up my 33's and 35's in the next week....so Ill update pictures then. Just for giggles I included the pic before the body lift.
If I was going with 31's I wouldnt do a body lift.
On a side note, Im pulling the transmission and tcase today. The body lift did WONDERS for the amount of usable space down there. SOOOOOO much easier.
Also...FYI an engine hoist works amazing to lift your body without doing any damage. My high lift was gonna bend stuff up, and so was the tranny jack I tried. The hoist was perfect.
Old 08-12-2009 | 01:36 PM
dakota33's Avatar
dakota33
think you could get me the exact web site for those terras?.. Im interested...they would ship to PEI eh?
Quick Reply: Body Lift and Torsion Crank questions
