Sticky Rear End?
Old Oct 17, 2009 | 10:48 PM
skyshark186's Avatar
skyshark186
Your "supposed" to do that with most automatic locking hubs/transfer cases, but its usually not necessary. It still really sounds like you have a tcase issue to me. If you have the transfer case in neutral at any time the truck should move freely.
I guess I dont understand the term sticky? Do you mean it has more drag than normal? Sorta like your towing something?
Try this. Put the transfer case in 4wd, then pull it into neutral and get under the truck. See if the front driveshaft will spin freely by hand.
Old Oct 17, 2009 | 11:20 PM
Crazy4x4RT's Avatar
Crazy4x4RT
To me it also sounds like a transfer case problem. Like as if it is not fully disengaging 4wd. Could be a simple adjustment on the sift linkage.
Old Oct 17, 2009 | 11:23 PM
95_318SLT's Avatar
95_318SLT
Yeah, still sounds like a t case issue to me too. One thing I didn't think of when I was giving you advice is... why would it just simply slide into neutral if it wouldn't slide into 2wd without problems!!!
My next idea is put it in 4x4, make sure 4x4 is fully engaged, pull the shifter back into 2wd, jack up the back axle and try spinning the tires by hand. If they spin (should spin in opposite directions if you have an open diff and the driveshaft shouldn't spin at all), then there can't be any binding in the rear axle.
Old Oct 18, 2009 | 01:39 AM
'95Dakota's Avatar
'95Dakota
alright. Thanks for the advice.
And skyshark, its lke the parking break is half way on, then once you get to a certain speed, it goes back to normal.
I dont have nothing to do tmrrw so i'll try to do some diagnosing.
Old Oct 19, 2009 | 10:40 PM
Hahns5.2's Avatar
Hahns5.2
It's a live front axle, the driveshaft will never spin with the tires on the ground.
Try backing up after taking it out of 4wd, the constant forward pressure can keep the t-case locked in 4wd, I know my truck will do it..
Old Oct 20, 2009 | 02:30 AM
pioneerbirdy's Avatar
pioneerbirdy
With the front axle just lift one tire off the ground or both if you want. if you have 4 jack stands just lift it totaly of the tires.
Old Oct 20, 2009 | 09:37 AM
'95Dakota's Avatar
'95Dakota
I tried that. Theres a post of what happened already But, it still fel like it was "sticky", but not as bas as when i just drove forward.
I havent been able to go out and look lately. I've been sick so im tryin to get half decently better.
Old Oct 20, 2009 | 12:29 PM
spitfirenut's Avatar
spitfirenut
Dumb question, but are the tires all the same size? What are you on when running 4WD? Hard surface or grass? If there is a mismatch in tire size, the difference will cause it to kind of drag a little when you come out of 4WD
Old Oct 20, 2009 | 07:01 PM
'95Dakota's Avatar
'95Dakota
there all 245 Baja Widetrack.
When i did it, it was on wet (it was raining) pavement with a thin layer of dirt (making ti like ice) so it wasnt grippy.
