Rear end
Old Oct 20, 2009 | 09:08 PM
dakota33's Avatar
dakota33
Default Rear end
Ok.. so the question is, what can I do to make my rear end Posi, Im looking for LSD.. as I dont want a locker, because if im right doesnt this always lock and put premature wear on your tires?... I just need this, as I swapped to V8, and dont wanna be stuck there spinnin one tire... , so if anyone can guide me in the right direction where to buy this, what needs to be done.. and if it can work with any ratio.
Old Oct 20, 2009 | 09:14 PM
Hahns5.2's Avatar
Hahns5.2
Lockers unlock, that's the definition. A spool or welded diff does not unlock. Sure lockers can and do lock on the street and cause extra wear on the tires, I've personally never noticed any significant tire wear increase with a locker.
Old Oct 20, 2009 | 09:17 PM
dakota33's Avatar
dakota33
hmm, alright.. so , would a person like me be able to put one of these in? lol.. , if so , or if not. Where might I pick these up.. like for my exact year, 1995 dakota 4x4, cant guarentee but pretty sure 3.55 gears. and are they pricey?
Old Oct 20, 2009 | 09:22 PM
Hahns5.2's Avatar
Hahns5.2
A "lunchbox locker", like the Powertrax No-Slip and Lock-Right are much easier to install than an LSD since they only replace the spider gears and don't require adjusting the backlash. The No-slip goes for around $430, the Lock-right goes for a little under $400, the No-slip has some extra do-dads that make it smoother.
The No_slip Part number for the 27 spline 8.25 is 92-0382-2705.
95_318SLT's Avatar
95_318SLT
If you're truely set on not getting a locker, you could look for a factory limited slip rear axle and do a complete axle swap, or you could buy an LSD carrier and get it installed. If you've never done a carrier swap, you don't want to do this on your own cause it requires special tools and a very specific way of setting it up.
As for the locker thing, there are lockers that easily install in the open carrier in place of the spider gears. The Powertrax No-Slip locker is a popular one. They unlock when there is no torque transfer in the differential and you're turning and lock again when you get on the gas. From what I've heard, they take a bit of getting used to, especially making a sharp turn from a dead stop. Crazy4x4RT has one in his truck.
Old Oct 20, 2009 | 09:23 PM
95_318SLT's Avatar
95_318SLT
Wow, in the time it took me to type that, you guys already posted 3 replies! :P
Old Oct 20, 2009 | 09:32 PM
dakota33's Avatar
dakota33
ya, thats what I love about here.. quick responses lol, but first off.. we dont realyl have much trucks around here.. so dunno how easy it will be to find a LSD one, so thats why im thinkin of going with something to buy. Hahns, that part number, what site is that for?.. Im from Canada, so whatever im buying needs to be able to ship and close hah. The Powertrax No-Slip locker you said hard to get used to? in which way?.. its hard to choose what I want..
Old Oct 20, 2009 | 09:36 PM
Hahns5.2's Avatar
Hahns5.2
That is the Powertrax PN, type it into Google and you will find many places selling them. They take a bit of getting used to but with an automatic it'll be a lot smoother than my 5 speed. Basically use light throttle in turns to keep it from locking, or if you want to have fun, stomp it and go sideways!
Old Oct 20, 2009 | 09:42 PM
dakota33's Avatar
dakota33
hmmm, thats something I could have fun with , I will it right now!
dakota33's Avatar
dakota33
btw, does it matter on year of truck/ ratio?
